Question about Genius MaxFighter F-23 Joystick
While playing Wings of prey, my Genius Maxfighter f 23u doesnt work properly. On the horizontal axis, the left side is going wide to an end but on the left it goes only to half of it. The joystick physically goes to the end on the both sides of axis, but digital it goes like I wrote above.
4 Suggested Answers
SOURCE: X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Posted on Jun 28, 2009
SOURCE: maxfighter joystick not working in vista
EFO
Posted on Dec 16, 2009
jobsagoodun
  • 156 Answers
SOURCE: no consigo el enlace directo para descargar el
http://download.geniusnet.com/GAME/F-31UV.zip
Posted on Mar 06, 2010
Joystick f 23 unable to turn right
Hi all!
I'm used DXTweak program, and tweaked Z axis settings.
Black marker set to center, and deadzone set 100%.
I hope help:
Found it: http://forums.eagle.ru/showthread.php?t=42462
Cheers. Thomas
Aug 10, 2012 | Genius MaxFighter F-23 Joystick
I have a Vista and I can not use the mazfighter f23u joystick (genius)
Yeah Vista is not friendly with a lot of Pre-vista hardware and software. Go to the manufacturers website for your joystick and see IF they have the Vista Driver you need for it to work on your vista machine.
Once you download the new driver, go to:
Control Panel
Device Manager
Find your device
Right click, and it should give the options to "change Driver".
It will ask you to choose location or have windows search for it
Specify where you downloaded the new driver to and hit enter.
It will ask you to restart machine and after that it should be good. Again, IF a driver for Vista exists.
Jun 03, 2011 | Genius MaxFighter F-23U V2. PC Joystick...
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
Is MaxfFighter F-16 U good to play with in FSX?
If this is a USB device and the driver has been installed, chances are it will work.
If you go to the Setup in the Flight SIM program and can select/configure the joystick, then it will definitely work.
Oct 09, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
I have installed and callibrated but still wont work when gaming
go in your game go options key confg set it to joystick and set controls if there is no opt. to change to joystick the game doesnt sapport the joystick
Nov 12, 2009 | Genius MaxFighter F-16U. USB PC Joystick...
Genius MaxFighter F-23 Joystick Logo
208 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
