Question about Keurig Platinum B70 Coffee Maker
Won't brew only drop at a time wiuth coffee grounds ]
  • 40 Answers
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Posted on Mar 29, 2011
The grinder works but coffee too light in colour and no foam
You didn't indicate what model you are using but it could be several things.
If your coffee isn't ground fine enough your brewing time may be too short. Your double espresso shot should take between 18-26 seconds to brew. A single should take between 9-13 seconds to brew.
If you are getting the correct brew time, try a different coffee bean. Some coffee is roasted more that others and that could be the reason the color is light. Make sure you are using fresh beans too.
Make sure you are putting the correct amount of ground coffee into the porto filter and tamping it well. A porto filter that isn't full will not brew a good shot.
Sep 22, 2016 | Faema Coffee Makers & Espresso Machines
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Coffee grounds (unused) dropped into dregdrawer tray
try to make the grinder position on 2.
And where exactly is the unused coffee-in the drawer or under the brew unit? Did you try to wash the brew unit with water-fill a box with hot water and put it into box. Leave it all night and in the morning just clean on the water and dry it.
Let me know what is result when you done it!
Apr 14, 2015 | Gaggia Titanium Espresso Machine
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
I have a Gaggia Titanium that's stopped working. The coffee will brew and grounds. But no coffee comes out. If I open the steam knob coffee coloured water comes out. I've the the brew unit. Also if I...
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the frontside towards the door. 2 screws (some have 3) hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.
Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
Grinder turns, but despite being full of beans, says "Cof. Beans Empty" - have cleaned thoroughly en used compressed air to rid any ground coffee that may have caused a blockage, managed to make 1 cup,...
Hi
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine above where the brew unit sat, there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back towards the center of the machine, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Oct 23, 2010 | Saeco Royal Cappuccino Espresso Machine
Ground coffee piles up before getting to steam unit
HI
There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
If that didn't do it. Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper and follow the first part again.
Dec 01, 2009 | Saeco Vienna De Luxe Espresso Machine
Have saeco type sup 021 r it is saying it does not have coffe grounds but it is full tryed spreding around turning it off but still light is on needs coffee
Hi
Once that is cleared go to the bean hopper. There is a lever on the right side of the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Nov 09, 2009 | Saeco Royal Digital Plus Coffee...
Keurig Platinum B70 Coffee Maker Logo
121 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
