Question about Electrolux Dryers
CAN I WALL MOUNT MY ELECTROLUX EDE605 DRYER ON THE WALL.
    New Friend:
Hey, this is very nice and informative article and please keep posting the amazing article like this Dewalt Cordless Drill Best Cordless Drill
Posted on Sep 21, 2017
    Scholar:
  • 89 Answers
I would not advise it.
Posted on Sep 22, 2011
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
How do i fix dryer to wall ?
You cannot mount a dryer on a wall OR mount in on a wall upside down. Unless it has been specifically made for this purpose...which is very unlikely.
Feb 25, 2016 | Dryers
How do I change the 3 prong wall mount to a 4 prong wall mount for a dryer?
Since you are asking, I would not suggest you try it. 240 volts is deadly. It would be easier to change cord to 3 prong and then add grounding wire from back of dryer to cold water pipe. The 4th prong is a ground connector, new standard for safety. Your house wiring may not be set up for it, or it might be. Unless you know what you are doing, let someone who does do it for you. Be safe pls
Mar 06, 2015 | Dryers
Electrolux wall mount micro wave oven combo doesn't work
Good Morning Friend,
I understand that your Electrolux wall mount microwave oven combo is not working. I see that the oven is working, but the microwave is not. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EI30MH55GS Microwave Oven
I have ane electrolux dryer with reversible doors. I would like to keep the door opening to the left, but it hits the wall. Is it possible to adjust the door to make it stop before hitting the wall?
Hi Wendy, this is AP
I understand you want to reverse the door opening on your Electrolux dryer. I would be happy to assist you with those instructions. Are you able to provide the model number for your dryer? If this is a new dryer you may visit the manufacture website, locate your appliance, scroll down to bottom and you will see a listing of documents available, the installation instruction manual will have the reversal instructions listed. . I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thank you,
Mar 21, 2014 | Electrolux Dryers
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
I have an Electrolux ede605 dryer and the hot air works but the spin cycle is getting very slow.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore Dryers
Dryer is making a noise that sounds like something is loose in the drum it is still drying very loud at first then gets quieter as it goes.
The dryer drum rides on a center bearing (plastic on metal mount). In time the plastic bearing disintegrates and the ball begins to rub the metal mount. If left like that after a while the ball will be cut in 2.
Another thing that goes south is the plastic slides that the drum rides on in front.
My Electrolux Dryer repair page
Mar 29, 2011 | Frigidaire Dryers
Electrolux edc77570w dryer is locked and displaying lock symbol, how do i unlock it?
the only way i know of this is pull the plug out the wall socket then take the lid off the dryer and look down inside to were the door lock is fitted you should see a pull cable that unlocks the door give it a tug and the door should pop open? we hope???
Oct 25, 2009 | Electrolux Dryers
Dryers Logo
380 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
