Problem with Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
112 people viewed this problem
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Source: Help....kenmore trio refrigerator, error message "er co"
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Source: Kenmore Elite Trio Refrigerator not cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Testimonial: "That's what my fridge is doing? Thanks for the help."
Source: Kenmore Elite Trio Fridge Not Cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Source: 1 year old Kenmore Elite Trio Refridgerator not cooling
Did you ever get the problem fixed with the compressor noise
Source: Kenmore Elite Trio 596 73503200
This is the 1st (and easiest) step to take:
1. Turn power off to the refrigerator (i.e. unplug)
2. Leave OFF for at least two minutes to allow the CPU to reset
3. Turn power back on (plug in)
This solves 98% of these problems with the Kenmore Elites.
Step two would be to call service.
Source: Kenmore Elite Trio 795.7519
Fridge section has stopped cooling but lights are still on; freezer appears to be working fine. Fridge is not cooling...
We moved homes and setup our trio, it is giving me an error code of what I assume is 15 or I5, either way I still can't...
My Kenmore Elite Trio Bottom Freezer with in-door water dispenser started accumulating frost in the front of the freezer...
Kenmore Elite "Trio" Refrigerator. 5.5 years old. Stopped cooling (and freezing). No problems till this time. Fans run....
Our Kenmore Trio 596.76512500 freezer works, refrigerator section stopped cooling.
JennAire Top and Botton Fridge turns on and off every two minutes.Freezer/fridge still working. Coils warm. Dusty...
Model No. 795.71303.012 Refrigerator is set at 39 deg F, Food on the top shelf is freezing
moved unit to new home plugged it in and it does not seem to be getting cold
Sean Miller Hi whats the model number? And is the freezer cooling or neither the rerigerator or the freezer?
Mar 26, 2011
