Question about LG Washing Machines
I JUST BOUGHT A LG WASHER MODEL NUMBERWM2050CW AND PUT A LOAD IN AND THE WASHER DRUM WOBBLES WITH NOT EVEN HALF LOAD ON WASH CYCLE
    Guru:
  • 500 Answers
It is likely that the Transport Bolts have not yet been removed.
See below a image and removal instructions found in a L.G Manual:
It is a very simple removal procedure.
Hope this helps, need anymore help - Let me know :-)
* A Four Thumbs up and a neat Testimonial if this helped you
Posted on Mar 26, 2011
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
Is there any way to adjust my front loader Samsung to have more water during the wash cycle? I was washing one light blanket and during the wash cycle I had to add a dish towel, when I put my hand into...
Hello
Remember this washer is a water saver.I have the same question on my new washer.What i do is increase the size of the load.
Instead of running it on light load, ill put it on heavy this will allow more water to fill.
May 04, 2011 | Samsung WF203ANW Front Load Washer
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
Washer tub wobbles, washer is level, on spin cycle the tub wobbles so bad it sounds like the tub is hitting the washer.
Sounds like a drum bearing problem , unless you are an engineer , suggest call service agent for estimate.
Nov 08, 2009 | LG WM2101HW 4.0 cu.ft. Washer
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
May 23, 2009 | Candy CNW136 Front Load Washer/Dryer
Washing Machine Stopped Flashed ''LE''
First remove all clothes and look for anything like a wash cloth that may have become stuck, then remove the cord from the wall socket for at least 30 minutes to be safe, and try this again if doesnt work the first time, two, move the drum by hand, close the door, and see if fires up, if so run a 20 minute custom light duty cycle, third replace the drum positioning sensor, 6501KW2001A.
It can be bought on line for between 25 and 40 bucks
Will
Nov 12, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
