I have a hoover 750LB 7.5kg washing machine. My washer was working well until last weekend when we moved house. Now when I use it.. The water from the tap doesnt stop flowing. If I open the lid, I can hear the machine stopping, but the water still flows. Could it be something to do with the hose itself? As the hot water works fine and stops flow when I open the lid. The cold water will stop when I manually turn off the tap then turn it on again. Please help!
  • 1 more comment
  • martmajick Mar 27, 2011
    thanks so much.. Did exactly what you said and it did exactly what you said it would.. Will get the replacement part tomorrow (its sunday and everything is closed). Thanks again.
  • martmajick Mar 28, 2011
    the swap went perfectly.. Thank you so much..
    dcramer531 was wonderful. Thanks so much.
    President:
  • 1,654 Answers
What you have is a failed water valve, to test this just switch the hoses on the valve and turn it on hot and low level and see if the valve doesn't turn the water off. If the cold water coming out of the hot water valve shuts off then the cold selenoid is bad. these are a cheap and easy fix. You can do this yourself and save some money.I beleive the selenoids are around $10.00-20.00 US each.
www.youtube.com/watch?v=pB5PbSumfS0 Here is a video of the repair. the valve looks like the picture below.
Posted on Mar 26, 2011
  • Dcramer531
    Dcramer531 Mar 26, 2011
    If you find that the water valve is still not rurning the water off after you swapped hoses, the it will be the pressure switch, but let me know how the hose swapping goes before we spend time on the switch.
  • Dcramer531
    Dcramer531 Mar 27, 2011
    Your welcome. glad yuo found out the easy way and not a service call. Let me know how the swap goes, like I said that is an easy fix but if your having issue let me know. If you find my hepl was useful I would apprciate the vote of confidence when your done and thanks for using Fix Ya
Whirlpool Supreme 80 washer
it sound like the water pump has an object in the housing preventing it from operating, take the back off the machine to get to the water pump and take it apart to clear the blockage good luck eric
Jan 01, 2018 | Whirlpool Washing Machines
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
We are renovating our kitchen & last week my husband moved thbe washer. It is taking in water but it then runs straight back out through the outlet hose....please can you help. It is a Hoover washer...
is the hose lower than the tub as this could lead to the water siphoning out due to gravity, the outlet hose standpipe should be at least as high as the top of the drum
Jul 15, 2008 | Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
