Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Top of mixer is wobbling when under load - KitchenAid KSM90 Ultra Power Series Stand Mixer
  • 4 Answers
This will happen. don't worry about it, these mixers are designed to be under load so just relax and don't worry about it. It will happen under heavy loads mainly, but sometimes heavy cake batters as well. Hope this helps, Sincerely, Luke :)
Posted on Mar 26, 2011
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: My mixer is a lift-top and the top seems to be
Hi, W/D here.
If you raise the head of your mixer, and look under the raised part, you'll see a silver screw head with a slot for a standard bladed screwdriver. Tighten that screw, and that should do it.
Best regards, --W/D--
please feel free to rate this solution!
Posted on Jan 31, 2011
The planetary fell off the mixer a few months ago. It has done it a few times since but happens much more often now. When I went to put it back on this time I noticed the that you put it on was very...
The planetary is held in by a push pin. I suspect this is missing. Now the base where the planetary inserts is damaged and allows a wobble. This is very bad since that is molded into the main case of the mixer.
Jul 02, 2012 | KitchenAid Food Mixers
My kitchenaid stand mixer arm wobbles when I turn it on.
if the head wobbles on stand, flip mixer upside down, and tighten the pivot pin screw way deep down inside stand. you will need a long flat blade screwdriver. it's probably loose.
May 13, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Top part of mixer is loose. how to tighten?
I had the same problem.. not the top plate, but the whole head was wobbly. I fixed it by removing the top plate, then locating the three screws that hold the top to the base. These screws are under the motor. I had to remove the motor, but this also required taking the transmission cover off. Sounds harder than it really is. Once I tightened those three screws, the play went away.
Feb 18, 2011 | KitchenAid KP2671 Professional 6 Series...
My mixer is a lift-top and the top seems to be loose and wobbles as it mixes. help?
Hi, W/D here.
Jan 31, 2011 | KitchenAid 32685 Mixer
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Beater hitting bowl. Very wobbly, won't stand still when
More likely the pedestal base is bent. Your local service agent has probably seen it before and should be able to bend it back flat again. It's a brutal process with a heavy soft hammer that you probably won't want to see.
Jul 15, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid wobbles when mixing
Do not store or transport the mixer on its side ever. Always upright. The grease in the gearbox should even out eventually. Try sitting on it when it wobbles. At least yours works.
Dec 26, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
37 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
