Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Reinsert cassette warning over and over. new cassettes, same problem... was working fine one day and started getting reinsert cassette warning the next. camcorder has hardly been used, less than 20 x probably... it is very clean, no damage... what is going on?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Apr 01, 2011
My camcorder keep saying reinsert cassette
Try reinserting a Brand new Cassette . If this dos`nt work take the battery out over night reinsert the battery with the Brand new cassette in it .if you used the recorder to play very much footage as a viewer it has over heated it . the sensor that sense`s a cassette is just a little out of place with a little skill and if you know what you are looking for you can put this back in possition!
Aug 30, 2011 | Sony Hi8 CCD-TRV138 Camcorder
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
http://www.retrevo.com/c/sohohelp/blogs/show/6633/I-just-had-my-espon-artisan-800-replaced-and-the-refurb-keeps-saying-that-the-paper-cassette-is-not-seated-correctly#replyForm
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
The screen keeps saying reinsert cassette and I reinsert the cassette and it says it again. I tried a new cassette and same thing.
Take it to the repair service. I am really suspect who's still use a reinsert cassette so today,Refer to old Sony DCR-TRV285E Accessory ,and I didn't know a Sony DCR-TRV285E Digital-8 Digital Camcorder model ,please say clear and correct !
Dec 16, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Reinsert cassette message
Believe it or not, after having the same problem "re-insert cassette" and "reattach power source", and after talking to Sony and them telling me it would be $111.00 to repair, I hit mine with the palm of my hand twice on each side and twice on the back by the battery and it actually worked--haha Go Figure!!
Dec 10, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Reinsert Cassette Error
Hi, I had the same problem. When I inserted the new (or old ) cassette, it was showing me the same simbol as you are describing here.... The one thing to do here is to let it check in some CamcorderReparingCentre. After I let it to repare it they told me that there was some kind of engine broken , I paid £60 for reparing but my camcorder is working again,properly like before...
Apr 18, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
Nov 20, 2008 | TruTech T350B Boombox
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
35 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
