Question about Compaq Presario SR5712F PC Desktop
Compaq Monitor WF 1907 immediately after the Desktop /Monitor (set at VGA) is turned-on gets stuck at the COMPAQ sign in the center and F10=SetUP, EXC=Boot Boot Menuplus F11=System Recovery all displayed as well. So, how do I get it to boot properly?
  • 31 Answers
Try using your windows cd to boot up the computer and if that does not work then you may need to reset the bios. Inside the case if it is desktop there is a way to reset the the bios. There is a jumper that needs to be switch then switched back that will reset the bios. If this does not work may need to get a new hard drive. The MBR ( Master Boot Record) may have been corrupted.
Posted on Mar 26, 2011
Where can I buy a cable to connect my WF 1907 to my computer?
dvi(white) or vga(blue)? vga you can get at walmart but dvi is not so widely used. i believe they carry it though.. if not try amazon
Feb 04, 2011 | HP Compaq WF1907 Monitor
How do i get sound to come out of my WF 1907 moniter?
Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and adjust the volume up.
If the issue is not resolved please check the link
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01289551&product=3351970
Aug 06, 2010 | HP Compaq WF1907 Monitor
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
Monitor going to sleep
Try checking your Windows settings by right-clicking on the Windows desktop, then properties. You will be able to see Display Properties dialog box. Click on ScreenSaver, then click on Power Saving.
Look for "Turn off Monitor.." you can set it to "Never".
Feb 18, 2009 | HP Compaq FP5315 15" LCD Monitor
Compaq wf 1907 monitor speakers--no sound
make sure they have not came unplugged from the computer also on many keyboards there is a mute button, make sure it has not accidentally got pressed
Jun 06, 2008 | Compaq Presario 5000 PC Desktop
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Compaq Presario SR5712F  PC Desktop Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
