Question about Provo Craft Cricut Disney Font Cartridge
Replaced the entire blade housing because it wasn't cutting through paper- were told the housing was the problem ordered a new one- so now, new blade, new housing, has a new mat, and still won't cut through regular cardstock even when pressure is dialed to max and blade dialed to 6.... what could be wrong? Please help!!!!
4 Suggested Answers
CricutAddict
  • 13 Answers
SOURCE: The cricut does not cut through the paper, it only
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
Posted on Mar 25, 2010
SOURCE: I purchased a brand new
can u help me my cricut will not cut..can any one tell me were I can get work on it..
vlvan@q.com
Posted on Dec 04, 2010
SOURCE: WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
Posted on Oct 17, 2011
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    What is a deck for a JD L110 mower?
    Yes. The deck is the metal housing that holds the blades, spindles eyc. The entire unit is a deck assembly.
    Oct 13, 2016 | John Deere L100 Series
    Uneven Cutting with my Zero Turn 50"...Possible Causes?
    First is being sure all your tires have proper air pressure and you don't have a bent blade. Then while parked on flat concrete and both outside blades at 3 and 9 o'clock measure blade height far left side of deck and far right side and compare. I there is a difference the entire deck is out of level and should be adjusted. Then remove the blade drive belt from one of the pulleys so everything is slacked. Grab each blade and see if it wobbles or has excessive play and check the spindle housings for cracks or breaks. If you find a housing with wobble or play the bearings in that spindle are shot ( this is a lot harder to detect with the belt tension on the pulleys) and should be replaced. If you find a broke or cracked housing the housing will need to be replaced. Either one of these situations may not be obvious with the mower at rest but the blade will wobble at speed causing uneven cuts.
    Aug 25, 2014 | Garden
    Blade not cutting through paper with setting of 6 for pressure and dial on blade at 6
    First make sure the blade is in tight, if it's even a little off it won't cut right. When I have the no cutting on 6 and 6 I do a double or triple cut to make sure it goes through all the way. It just seems some paper is tougher.
    Mar 16, 2013 | Cricut Expression Cutting Machine
    It will come on but when i put the paper there to shred it, it wont do anything.
    I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
    Apr 22, 2011 | Aurora Electronics AS-650C Cross-cut...
    Cuts uneven, lawn looks terrible. Missing half
    Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
    May 28, 2010 | Garden
    Not getting clean/sharp cuts
    the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
    Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
    Cricut not cutting anymore
    I was reading lots of forums and tech support pages on how to get my Cricut back online. I went to the store and got the Deep Cutting Blade & Housing and I got two replacement blades for the original housing that came with the Cricut. I also bought a pack of new mats. I replaced the original blade with a new one, used a new mat, and tweaked the depth and speed of my cuts and my little Cricut is whirling again!
    Jun 25, 2009 | Provo Craft Cricut Disney Font Cartridge
    Provo Craft Cricut Disney Font Cartridge Logo
    51 people viewed this question
    Top Provo Craft Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
