Question about Gateway P-7805u FX (L-LX.W430X.013) PC Notebook
Black screen during gaming default graphics settings, no overclocking forced to hard restart..only remedy is to use rivatuner to force 3d performance..at the cost performance during gaming. Gateway p-7805u Did reformat, installed new OS, cleaned fans, applyed a superior thermal paste, had the gpu reflowed..issue persists.
  • 112 Answers
I've had a similar problem on my Dell Studio laptop. Windows Update will force an update to the graphics card driver, and the result will be full of bugs. To fix, consult the graphics card's manufacturer website (Intel, nVidia, AMD) and download the correct driver for your graphics card. Uninstall the current driver using Device Manager (Windows Vista/7 just type in "Device Manager" to the start menu search. Expand the Display Adapters section. Right click on your graphics card and select uninstall.) You should then be prompted to restart your computer, do so. Once your computer has rebooted, install the new driver downloaded from the manufacturer's website, after it installs you should again be prompted to restart, do so. Once rebooted, problem should be solved.
If I helped you, please give me a 4 thumbs up rating. If you still need more assistance, comment back and I'll be happy to continue helping.
Posted on Mar 26, 2011
  • perneir Mar 27, 2011
    It was a no go. I had the current drivers even before trying the solution you provided. Was worth a try though. From my research I beleive that a reballing of the gpu may be neccessary although I have had the gpu reflowed and it did absolutley nothing to resovle the issue. Any other suggestions, minus the things I have tried so far of course?
Format corsair force gt ata
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
May 13, 2012 | Computers & Internet
Spiderman friend or foe doesn't work
The most common problem shall be that your system might not meet the minimum requirements that the game needs...If you are sure that the requirements are met then you shall try to get another fresh copy of it as this may be corrupted.....If the minimum requirements are not met you can emulate the graphics that is needed for the game using 3D analyser....
May 10, 2011 | Activision Spider-Man: Friend or Foe for...
DOUBLE CLIK ON ICON ITS SHOWS SPIDERMAN FRIEND OR FEO MAIN APPLICATION HAS STOPPED WORKING
try to reinstall the game. it sounds like theres a problem with the installation files
May 04, 2011 | Activision Spider-Man: Friend or Foe for...
Games crashing to a black screen
Check the game's compitablity with your graphics and the ram card.
Aug 30, 2009 | ATI RADEON® X1950 PRO (256 MB) Graphic...
I have a nvidia geforce 9400 Gt graphics card how can i overclock
Read this...
You're not going to get a lot out of that card, it's pretty stripped down being a 9400. Anyways, download Rivatuner then after it detects your video card it will update your registry which will allow it to manipulate your video card.
You then use it to increase your Memory and Core clocks, and also the shader clock in VERY small steps. Increase it by perhaps 20MHz then try playing the most visually demanding game that you own and play it for like 5 to 10 minutes and watch for anything out of the ordinary. When you've pushed your card too high there are obvious signs, like random pixels flashing across the screen, textures showing up wrong (colours where they shouldn't be), or your game can simply lag or crash.
Also download Speedfan and monitor your GPU temperature closely. See what it idles at normally, then use Rivatuner to increase your fan speed to somewheres around 75% and make sure that the temperatures don't pass 70C.
Overclocking voids warranties and you can damage your graphics card if you push it too hard. You have to be careful and watch for signs that it's being pushed too hard. Also, you have to make sure that you set your clock speeds back to normal when you don't need the extra power. It's easier on your card then running it at 120% or something permanently.
Rivertuner: http://www.guru3d.com/index.php?page=riv…
Speedfan: http://www.almico.com/speedfan.php
Hope it helps...Good luck
Jul 25, 2009 | Computers & Internet
When i try to overclock the graphic card using the ATI CCC software, the computer hang and the screen turns completely green. Even a very minor increase in clock speed can result in this.
Just to let you know, an integrated graphics chipset cant be overclocked. If you are using a pcie graphics card there should be no problem- what make/model is the card. If the card is Nvidia you can use Ntune or if it is an Ati card you could use rivatuner
May 15, 2009 | Computers & Internet
Graphics
Use the latest graphics driver to correct this issue. if your video card is onboard look for the model of the board in download the driver in the internet. Also if you have external video card try to re install the video card driver to fix the problem.
Note: If you continue to experience issues running the game with the latest graphics driver, try running the game with the -w switch which forces the game to run in a window.
Apr 16, 2008 | Intel 845GE Motherboard
Nvidia 6600 256 mb agp
Check the temps of your card using rivatuner and the cpu with speedfan to see if they are overheating.
Are you running either overclocked?
Jan 05, 2008 | XFX GeForce FX 6800 (256 MB) Graphic Card
Overclock MX440 64MB in Vista
to be honest, the MX440 is rather outdated, especially with only 64mb sdr, to make gaming experience better graphically, the minimum card you will need would be 256mb ddr and no doubt windows vista would look better also.
Mar 08, 2007 | Nvidia GeForce4 MX440SE 64MB SDR AGP with...
Gateway P-7805u FX (L-LX.W430X.013) PC Notebook Logo
459 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
