Question about Breadman TR2200C Ultimate Bread Maker
I think I may have messed up the clips???
You say don't mess up the clips,... well.. what if I touched them already and bend them upward (which didn't make a difference at all) Is it too late for me??? I loved this machine! What happens now.....?????
Thank you for any info!
JoyceC777@aol.com the breadpan would not stay put, It would ride up from the agiator and bang around and not move the paddle inside and do zip for the bread making process. It stopped right there. The book said to bend the clips, Did and the same problem, Looks to be engineering design issue. Notthing there to press against the upward pressure from the agitator that to is revolve the paddle. What to do?
  • 659 Answers
They should be bent away from the walls they are mounted on and if you have tryed this maybe either it has not been bent enough or it has been bent too much when looking at them from the side it should almost be a quarter moon shape. if I where you I would attempt to try a few more times making sure both left and right clips are about the same distance out.
hopefully it will snap into place.
Posted on Aug 03, 2008
  • Wesley Gardner
    Wesley Gardner Aug 03, 2008
    if its just the one tab in the unit it might need to be bent out more. I just found the manual for this unit and looked at it the one I have has two I beleive.
How can I get into my 1996 Nissan maximum if I locked keys in car.
its possible to slim jim it. i had the same problem. but you can mess things up, like unhook the little wires that make your look work. happened to me,and was a pain in my **** to clip it back on cause very little room to work with. so be careful doing it.
Or you can possible get a hanger bend it inot once solid pieve with a 90 degree bend at end,and try to pull back on the top part of the door, pull it through top and use power lock inside. check and it should work,just you might mess up the door seal.
Otherwise get an AAA technician to unlock it for you at a cost.
Feb 09, 2015 | Nissan Cars & Trucks
Remove rear bench seat
I don't know about your exact make, but every bench rear seat bottom I ever messed with removed as follows:
Get your fingers under the bottom of the seat cushion, and give a sharp tug upwards.
It should be held in by spring clips, which will release with the upward tug.
With the front of the seat cushion slightly raised (so the spring clips can clear the brackets), it should then pull straight forward and out.
To re-install, push the cushion back under the seat back (with the front slightly raised), and with both hands, give a sharp push downwards to latch the spring clips.
Apr 24, 2014 | 1998 Nissan Pathfinder
I have a 1997 pontiac grand prix gt. I need help bad. My car has constant power running through it and its killing my battery. I think it started when I had my buddy redo my radio so I think he messed with...
As with any battery drain, you would pull the fuses and disconnect the major circuits while watching a test light or meter that is showing the drain. When you find the circuit in question the light goes off.
Then the fun begins trying to find the source of the drain. In your case you may want to start with disconnecting the radio. You may need a shop manual to get the wiring diagrams.
Jul 10, 2013 | Cars & Trucks
Suddenly my screen resolution got huge. how do i go back?
Go: Start -- Control Panel -- Display -- Settings -- To the upper left it says Screen Resolution. Adjust this upward and click "Apply". You may have to toy with it a few times to figure out which one it is actually supposed to be on. But don't worry, there is nothing there where you could mess anything up - after all...its already messed up. :-)
Anyway, if memory serves, going up gives you finer resolution, which makes things smaller. If you get there and its already all the way up, over toward your right, then my memory is backwards.....so just take it the other way.
And look at this as a blessing. You'll know more about your computer than you did. And - its a useful thing to know because if you ever plug your computer into a larger screen (like your TV), you will need to make adjustments here at this screen.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Acer Computers & Internet
Sansa clip+ ......dropped about 400 songs.....tried to download after cleaning out old songs, but to no avail....tried drag/drop from playlists AND library......the few songs that are left, when on skips...
Only thing I can think of is to start over, and hope there is no problem.
Then you will know if you screwed up, and don't know how, or if the thing is messed up.
Try a different method of loading tunes onto it.
try everything
PLEASE RATE THIS ANSWER
Aug 29, 2011 | SanDisk Sansa Clip MP3 Player
I have fitted new engine and trans to 1981 Corvette and have disconnected all the old computer wiring as am no longer using computer chip.What is best way to go about getting power to fuse box.Have power...
Run a cable from the battery positive to the fuse box. Don't mess with the wires in the clip they are for the regulator. once you get power to the fuse box, you have power there from the ignition.
May 01, 2011 | Chevrolet Corvette Cars & Trucks
My philips dvdr3510v player is not opening tray its saying blocked how do i solve the problem
This seems to be a manufacturing problem. When the disk is loaded it is centered on a spindle and to make sure that centering succeeds a magnet mounted to a small white rotating plastic piece on the top of the DVD drive. The magnet seems to bee too strong on my machine so the spindle isn't able to disengage when trying to open the tray. The result is blocking. It is of course possible that the electric motor moving the tray and the spindle movement is too weak. Anyhow this is how I solved the problem on my Philips Video/DVS DVDR3510V:
1) Disconnect the device from mains power.
2) Unscrew the eight screws holding the top in place.
3) Unscew four black screws keeping the DVD unit fixed to the main body.
4) Carefully drag the DVD slightly back which allows you to rotate it to point sideways (this allows simpler testing of the mechanical working).
5) Unscew the two blank screws keeping the front half of the top of the DVD unit in place.
6) Using a small screw driver carefully bend the clips to allow the top plate to be removed.
7) Connect the mains power and don't ouch anything inside.
8) After startup try Eject/Load several times to ensure that the DVD unit is mechanically working OK. If the Eject/Load doesnt work with the top off there is no use going further.
9) Disconnect mains power.
10) Use a small felt tipped pen to mark the face of the small metallic (magnet) part in the center of the white movable component fixed to the top.
11) Using a small flat screw driver carefully open the clips holding the two halves of the white component together. Careful! The clips may break easily.
12) Cut small pieces of tape (or use thick drawing paper). The idea is to lift the magnet slightly upwards. We thus use tape or paper as shims. Notice that a hole is needed in the center.
13) When the shims are in place put the magnet back oriented correctly (if you didn't mark it test it against the spindle rotating the disk. The correct orientation is where the magnetic force is strong.
14) Mount the halves back into the hole in the top component and align the clips. Then press the halves together until the clips connect.
15) Put the top component back and clip it into place. No need to screw in the screws yet.
16) Connect mains power, don't touch anything inside.
17) Check that the tray now opens both with a disk and when empty. Check that a DVD is recognized correctly (too little pressure leads to disk loading failure).
18) If the DVD unit now works assemble it and you are done.
The first picture shows the white round plastic part that is modified on the left hand side of picture.
The second picture shows an additional support I glued to the top with super glue because the top is fairly flexible. Initially I thought this was the reason why the spindle got stuck. I think the extra support is unnecessary but i didn't bother with removing it.
Dec 29, 2010 | Cameras
Im rebuilding a char-broil master flame 7000, and i need to know how to get the burner off. there are a few lock pins and some spring looking things and i don't want to mess anything up. so how do i get...
Each Venturi Pipe is held in place by the spring clip clearly visible from below (2 total). From behind, simply pull down / backwards on the clip until it pops out of the slot and hangs loose. Repeat for other pipe. Then the burner lifts out by sliding backwards / upwards.
Mar 24, 2010 | Char-Broil 7000 Quick Set Gas Grill
No you can reset them again to the original position.
It will work the same unless you break them.
I just killed my TR2500BC that machine just plain stinks.
I replaced it today with a Sunbeam 5891.
Hopefully it will be better but the 2200c is a good unit.
I just don't like the pan holding system.
Aug 01, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
