Question about Ariston Technologies Dishwashers
I have just recieved my new dishwasher and confused as to whether i need to use salt or not?? my water hardness is 7 DH. IF so what type of salt do i use?
  • toni_bryan Mar 26, 2011
    The Model is LKF 720 Aus R it does say that failure to fill the salt container can cause damage to the water softner and the heating element???
    President:
  • 1,140 Answers
Hello Toni,
Yes, you need to use salt.
7DH is quite low in terms of water hardness, but according to Ariston specs, this is water-hardness level 2 (6 to 11 DH) on your washer.
Ariston instructions can be a little contradictory for level 1 as in one place they state: "We do not recommend the use of salt", while in another, they state "If the salt container is not filled, the water softener and the heating element may be damaged"
This washer should be filled with salt regardless of the DH level. Even level 1 uses a small amount of salt. The important thing is to set the level for the water hardness correctly according to the table above:
I hope this clarifies things for you. If you have any further questions or need assistance with setting the water hardness level on your washer, please let me know.
Regards,
BElectric
Posted on Mar 26, 2011
  • Ariston Tech... Master
  • 3,247 Answers
Please provide the full model number of your dishwasher.
I think 7DH hardnewss equates to about 13 degrees clarke. According to Ariston the salt is required only when hardness is about 13.
You can run dishwasher wihtout salt and see if the dishwes come out clean.
You can then add the salt. The salt is specifically for idshwashers. Check you local supermarket to see what they have go.
Make sure you have the salt setting to 0 on the slalt container. Check your manual.
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
Tip
Conversion chart for dH to Clark BOSCH EXXEL Dishwashers
I couldn't find any info on my new BOSCH EXXEL dishwasher the codes in the manual are all in dH (german) while the H:XX codes mean nothing unless you have this table I created here it is for you all so you don't have to worry, it has all the conversions between Clark, dH and mmol/l and mg/l if you find one that applies to you just look across the table and find your corresponding H code.
You will need to go to your suppliers own website to find one of the above numbers for the quality of water usually in mg/l they will give you this value and then you can select the H code for you area.
Water hardness is measured in either European °E (clarks) or in the German °dH( Deutsche Härte) you will find this on all Bosch Dishwashers if you water is Extremely hard then you will need to program your Bosch dishwasher using the Code H:06 to give you maximum protection, if your water like mine is Extremely soft then the H:00 works well and also saves you loads of dishwasher salt.
HARDNESS CHECK TOOL
• Clark degrees (°Clark)/English degrees (°E) conversion to mg/L calcium: divide by 0.175 One degree Clark corresponds to one grain of calcium carbonate in one Imperial gallon of water which is equivalent to 14.28 parts calcium carbonate in 1,000,000 parts water.
•Deutsche Härte (German hardness) (°dH) conversion to mg/L calcium:divide by 0.14 One degree German corresponds to one part calcium oxide in 100,000 parts of water
on Dec 12, 2009 | Dishwashers
What do these lights mean there not going off
My machine says it needs salt. My glasses have a white cloudy film. Is this related? Where do you put in the salt?. I see no container. How do I determine the hardness of my water?
You should be able to insert the salt into a container at the bottom of the machine. There should be a screw-top on it. Refer to the user manual on whether you need salt, and how to insert it. The manual/ documentation may have come with a single- use hardness indicator. Alternatively, you can purchase hardness indicator strips. If your electric kettle/ shower has large amounts of white calcium 'fur' in it, they this is a sure indication of hard water, and you should consider using salt
Aug 26, 2011 | Miele 24 in. G643Vi Plus Built-In...
We have a new dishwasher, and we have a heavy white film on glassware and plastic glasses in the upper tray after use. What is the cause and what is the solution?
Its sounds as though your water harness is very high.
You have to add salt into the salt dispenser and set the machine for the "hardness" value in your area.
Your water company can tell you how hard the water is.
With the correct setting on the machine it will release salt to soften the water.
The salt you need is not cooking salt but one for a dishwasher available from supermarket.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Frigidaire FGHD2433K 24 in Builtin...
Dishwasher powder
Check inlet water quality. It's hardness level. Use salt meant for dish washers. There will be a salt fill compartment. Refer user guide.
Finally check whether the rinse aid dispenser has liquid for dispensing.
May 26, 2010 | Dishwashers
Connection a dishwasher to a normal water outlet.
If your dishwasher manual states connection to hot water then it does not heat its own water and needs to be connected to the hot.
Salt is used to overcome the hard water problems often found in England, Hard water deposits will always be a problem if no softener products are used
Feb 24, 2010 | Dishwashers
Why is my dishwasher always needing more salt on a daily basis.It seems it can never be filled>
i thnk it showing water hardness more indication.
1)pls check whether any pump is there to circulate salt inside the machine(check pump working)
2)check the water pressure.
Jan 08, 2010 | Miele Premier-Plus Built-in Dishwasher
Dishes are cloudy and covered with a film when done
Refill your SALT container with 1kg of dishwasher salt.
Salt reduces hardness in water -and increases cleaning efficiency. If you have a little furr build up in your kettle - you need salt in your dishwasher to work properly.
If you do use salt, it may be the salt reservoir is blocked with caked salt.
Oct 02, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Sep 30, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
200 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
