Question about RCA 27V530T 27" TV
Horizontal width jitter after turn on, or picture gets wide and then back and forth!
    Scholar:
  • 90 Answers
Hi there, seems you're encountering horizontal width suddenly adjusted by itself. i recommend you unscrew the back casing, clean the crt board a bit and look for the capacitor on the secondary output of the transformer voltage chopper. it has this diode series with the output and filtered with electrolytic capacitor. if you notice bulgy appearance replace it with same type and farrad rate. most of the times it is unnoticeable by just physical checking. Some are leaky and can be determined using capacitance tester. The supply of the Vertical IC is not stable cause by this capacitor. replacing most of the capacitor wouldn't cost you much. hope this helps, please rate and vote
Posted on Mar 26, 2011
BRAND NEW TILLER WIRE HANGING DOWN BY CARBUREATOR BOWL WHERE DOES IT GO.
David try this there should be a piece of flat metal that is horizontal by the carb. bowl that you can push back and forth, it should have a hole in it. The end of that wire should go into that hole and you need to crimp that wire so that it stays in the hole attached to that piece I described that moves horizontally. Based by the picture of your tiller this wire is going control your throttle so that your tines turn.
May 01, 2016 | Yard Machines Tiller 208cc 18in Tilling...
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture has the jitters and horizinatl lines
Check power supply board for bad capacitors they will be swollen,vented or puffed up on top . Let me know if you need anymore help.
Mar 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Picture is too wide
please check the width section transistor and while it is good condition please check the power diode in width section near to lot and replace the fly back capacitor that range is high volt its situated near to lot.
Feb 05, 2009 | SAMTRON 55V 15" CRT Monitor
TV picture won't open.
The vertical sync circuit has gone bad...you'll have to have it repaired if you want to keep it
Jan 03, 2009 | Televison & Video
Picture to wide
This trouble symptom picture wide or"blooming", the picture becomes dim even with the brightness control full on,and there is an abnormal enlargement of picture or raster.Usually,the enlargement is uniform,but there may be some defocusing.In some circuits,the brightness control operatesin reverse(rotating the control for an increase in brightness produces a decrease) after reaching a critical point on the control. If the picture wide is not accompanied by insufficient width(a symptom of horizontal output failure) the probable cause is a high volatge circuit ony,particularly the HV rectifier and HV winding.Any circuit problem that reduces but does not completely eliminate the high-voltage output to the picture tube second anode can cause overscan. The most likely defects are leaking high-voltage capacitors,defective high voltge tube rectifiers,leaking high voltage leads,defects in high voltage circuit protective resistance,and shorted turns in high voltage winding of the flyback transformer.
Hope this may help you;
DON'T FORGET TO RATE:
Regards,
Sep 06, 2008 | Toshiba 32AF45 32" TV
PS27115 27" CTC197BC Horizontal Width Adjustment
probably shorted capacitor in pin cushion. and also a diode. is it bowed?
Mar 09, 2008 | Proscan PS27115 27" TV
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
RCA 27V530T 27" TV Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
