Question about Dryers
What color code do you use from a 3 wire power plug to a 4 wire power plug on a ge dryer is it red white black on the screws then the green onth exsting ground
    President:
  • 1,489 Answers
You are correct :: Red & Black go to outside screws, White goes to middle screw, green goes to ground.
Charlie
Posted on Mar 26, 2011
Want to switch a 4 prong plug to a 3 prong plug on a kenmore 90 series elec. dryer
ok,, easy one,, unplug, take the cover off of the terminal cover,, take your old cord off, on the 4 prong you will have a red, black, white,and green wire,, matche the colors up red on right, white in middle, black on left, the green wire will go on a green screw that is near the terminal block with a white wire going to it, take the white wire off and put it with the white wire on the terminal block,, screw the green wire to the green screw,, and relpace cove and your done
Jan 19, 2011 | Kenmore Dryers
Need instructions on wiring for a 4-wire pigtail on a GE Dryer Just moved, the new place has the new 4 prong outlet so I replaced my pigtail with the new 4-wire one. Need wiring instruntions for the colors...
put the white in the middle,red on one side black on the other doesn't matter what side or just copy the old cord,now you need to ground it with the green wire,take off a screw on the back of the dryer near the other three and attach the green ground wire to it and screw it back in,the green wire just has to touch the metal frame to ground it
Mar 14, 2010 | GE Dryers
How do I change the 4 wire to 3 wire plug
Move dryer away from wall. On the back of the dryer, near where the power cord goes into the dryer, there should be a small access panel held in place with 1 or 2 screws. Inside there should be 4 screw terminals. They may be color coded red, black, white and green. Make a note or take a picture of it before you go any further. Loosen the screws that hold the 4 wires of the old cord and remove. Install the new 3-wire cord, note that it will not have the green (ground) wire on it. After all is put back together, you should be good.
Nov 10, 2009 | LG DLE2514 Electric Dryer
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 | Dryers
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
