Question about KitchenAid KBRS22KG
What is the best tempurature to set the fridge at, and the freezer at?
    President:
  • 1,489 Answers
Standard is ::
Refrigerator @ 40 degrees F
Freezer @ 0 degress F
Charlie
Posted on Mar 26, 2011
Witch way to go to set frig to make it colder up or down
the best setting for fridge and freezer is the middle setting, if u have both set to high, it is bad for the fridge as it shuts out the fridge and opens up all the way for the freezer? thus not enough cold air for the fridge.
Mar 11, 2015 | Kenmore Refrigerators
Re: Tempurature Problems
The thermostat is likely failing intermittently, or the defrost timer could be failing.
Both parts can be tested (and should have been) by the repairman.
The defrost timer turns on and off to let the coils defrost - but if it stays off - can cause the rise in temperature. The thermostat, however, reports the temperature to the timer, so either (or both) could be to blame.
Have them tested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Whats the best temperature to set the freezer and the fridge on
freezer should be set for -18. fridge 3 degrees
May 21, 2010 | Refrigerators
GE refrigerator motor wheezing
check behind panle where the fan is may be ice defrost the problem area
Dec 01, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
How to set the thermostat? gaggenau fridge freezer
how to set thermostat on double door fridge freezer
Nov 24, 2008 | Gaggenau Refrigerators
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
Refrigerators Logo
61 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
