Question about LG LK45C
Model LFC20745sw, Bottom mount french door fridge, I purchased an icemaking kit LK45C and tried to install last night, I have water pressure to it but I am confused about which connection we attach the water valve connection? We had a set of wires that were taped together on the left hand side of the fridge were we assumed the water valve attaches but upon looking further we found another connection where the fan is connected too. The water valve connection provided with the ice maker kit has 2 wires a red and a blue wire, but no similar colors on the valve attachment. How does it connect?
  • 159 Answers
SOURCE: No water to the ice maker. No voltage to the inlet solenoid
icemakers work on a timed cycle and a timed fill. pressing the reset switch i would say solved your problem. I would switch the valves back to the way they were. The valve for the ice is smaller then the door water because the icemaker takes a small amount of water to fill. Good luck
Posted on Jul 22, 2007
JigSaw007
  • 157 Answers
SOURCE: ice maker on a LG LRFC25750ST
hello sir
Posted on Aug 22, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
  • 10 Answers
SOURCE: LG LRSC26930SW Ice Maker Replacement
Stanley2190 :
Yes !! you have a 1/4 inch screw that is holding the Icemaker/ wireharness in place.
Disconnect the power to the Refrigerator before starting replacement
Posted on Nov 01, 2008
SOURCE: Installing an overload switch (part #8201799)
I found the part I needed. Thanks anyway.
Posted on Apr 02, 2009
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
No water for maytag refrigerator
Is the filter down at the bottom of the fridge stopped up? It could be or it also could be a valve closed. Try disconnecting the downstream valve at the filter and see if you have water there. If no, then you definately have a clogged filter. When was the last time you changed the filter?
Sep 05, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Stopped making ice
I hate to say it.....heres a review "
This is the worst refrigerator I've ever purchased -- and it's all because of the icemaker. It's been repaired 7 times in the last 2 years thanks to having purchased an extended warranty. Predictably every 6 months, the icemaker stops functioning. There's a piece that jams. The repairmen are at a loss. I give up -- this weekend, I'm headed to my appliance shop and buying something different. Don't waste your money on this piece of junk...."
I think there is a genetic problem. Are you under warranty?
Mar 19, 2014 | Maytag MFI2266AES Stainless Steel Bottom...
My Kitchenaid French door fridge's water filter
If I remember correctly it requires a quarter to half turn to disconnect in the counter clock wise direction. May take some grunt to free it. If that fail try channel lock pliers and be careful to not break it. once turned it should pull straight out. Try that as maybe its not twisted into place properly to start and just needs to be pulled straight out.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 13, 2013 | KitchenAid KFCO22EVBL - French Door Bottom...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
We recently replaced the icemaker in our samsung french door refrigerator,the icemaker worked fine for a few days and now no water goes into it,, we replaced the filter as well
Hi my name is Sean, you will need to check water pressure going into refrigerator, If you have adequate pressure, you either have a bad main board, or bad valve, depending on the year the boards were a problem in this unit affecting the icemaker especially. Let me know if you need further assistance.
Mar 26, 2011 | Samsung RF265AA Bottom Freezer French Door...
Icemaker fill leaking on new LG LFX28978SW french door refrig
Do you have the "dummy filter plug" installed and not the actual water filter in the upper left of the inside of the fridge?
Jul 01, 2010 | LG Refrigerators
Our maytag model mff2557heb has a cracking and poping noise every few minutes and lasts for 15 to 30 seconds. it has done this since it was new 2 yrs ago. It is bothersom. What is the fix?
these sounds are normal for most new fridges. on some models you are able to get noise reduction kits that can be a pain to install. the sounds you are hearing is the gas turing from liquid to gas state.
Jun 07, 2009 | Maytag MFD2560HES Bottom Freezer French...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
105 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
