Question about Lexmark C544dn Laser Printer
My Lexmark C544dn laser printer just up and died - I had just put in new paper, hit print on my Mac and when nothing happened, I realized the machine was off. Yes, I checked the power cord at the machine and wall, checked the connection to the computer, turned the power button on and off, made sure the paper tray was all the way in etc. This machine is about 18 months old and gets light use. Help! Thank you!
    Genius:
  • 1,087 Answers
Please try to do the following steps
• Check the AC line voltage. Is the line voltage correct? If not connect it to the correct line voltage
• Check if the AC line cord damaged. If damaged replace the AC line cord
• Is the LVPS cable correctly connected at JLVPS1 on the controller board? If not Reconnect the cable at JLVPS1
• Turn the printer off, and then on. Does the problem persist?
• Damage to the printer is possible. Be careful to touch only one conductor at a time, Rest the probe against the connector to steady it.
• Replace the LVPS - Low-voltage power supply (LVPS)
Please contact Lexmark Technical Support for further assistance.
Posted on Jul 14, 2011
What does 200.04 jam error indicate?
Did you look the jam code up in the operators manual? might try going to the Lexmark web site and look up your model mite have a updated firmware that will fix that problem, also are you using paper that is authorized to be used with that machine? look up the spec in the op manual or web site, check the weight of the paper the paper draw rollers may be dirty clean with a small amount of soap and water.
Nov 17, 2015 | Lexmark C544dn Laser Printer
I have a Lexmark C544dn printer. I am getting a yellow haze on the right side of all pages printed.
Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
Sep 09, 2013 | Lexmark C544dn Laser Printer
Its an Error Related to a Paper Jam on the Paper Roll Tray!!!!!
Please Check the Inside of the Printer if there are any Bits of Paper which are stuck on it!!! That would cause this Error Message to Appear!!!!
Good Luck!!!!
Feb 21, 2013 | Lexmark C544dn Laser Printer
Found one of the wheels(Tyres) and black insert in the paper drawer when I exchanged A4 for A5 paper. Put the insert and wheel back but printer still not working - that is to say, paper is still not
The wheel you are referring to grabs the paper. You say it is not working. Is it not pulling the paper, jamming? Make sure the roller is installed correctly and firm. It is easy not to get them clicked in place. Recheck. Possible damage to the device that holds the roller as I call them but I doubt that. Just recheck your steps again. Use a strong flashlight so you can see real good.
Jul 24, 2012 | Lexmark C544dn Laser Printer
Our lexmark c544dn has a paper jam but when I open the front cover I do not see one. What else should I do?
Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
Aug 05, 2011 | Lexmark C544dn Laser Printer
Inkjet fabric paper stuck in lexmark c 544 dn against platinum
Use only recommended media for laser printers. To get more details about the different media supported you can refer to your user's manual or try the link below. http://bitly.com/mP1hB3
Aug 02, 2011 | Lexmark C544dn Laser Printer
Lexmark printer c544dn. The printer is saying to "82 Replace waste toner box"
Please click on the link http://bit.ly/psOcDA to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
May 10, 2011 | Lexmark C544dn Laser Printer
Receiving dark smudges on all copies......how do you take the drum or roller out to clean it? We did not receive a manual with our printer.....so any assistance would be apprecaited.
You can clean the drum, this will create more problems with print quality.
Please try the steps provided on the link below. http://bitly.com/pnWPRY
also try the steps below.
  1. Verify if media is supported and proper paper settings are set.
  2. Try to print with the paper type setting change to heavy on the printer. (Menu > Paper Menu > Size-Type > Tray1 > Type > Heavy Paper > Check button)
  3. If persist, go to Diagnosis Menu and change the fuser temp. setting to high on printer. (Diagnostics Menu > EP Setup > Fuser Temp > High > Check button)
For further assistance, please contact Lexmark Technical Support Center.
Mar 24, 2011 | Lexmark C544dn Laser Printer
We are seeing dark smudges on the paper. We do not have a manual and I need to know how to take the roller out and clean it.
  1. Print the Print Quality Pages (Config Menu>Prt Quality Pgs).
  2. Verify if the defect shows up on one color or all colors.
  3. If one color, replace Developer of corresponding color and PCU
You can also try the following:
If you need further assistance, please contact Lexmark Technical Support Center
Mar 23, 2011 | Lexmark C544dn Laser Printer
Printer driver for Mac OSX isn't working
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:284:0:0&framed=&docid=ENUS24591&relevance=1 This may just be the root of your problem. How to Install an Older (Legacy) Printer (such as the Lexmark Zx2) in Mac OS 10.4.7 (Tiger) ID:ENUS24591 Overview When an older (legacy) printer model is installed on Mac OS 10.4.7 (Tiger), some extra steps need to be taken because the Print Center cannot be directly launched. Thats the jist of the technical paper. Should help. Good Luck, Tim
Mar 08, 2007 | Lexmark JetPrinter Z22 Color InkJet
Lexmark C544dn Laser Printer Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
