Question about Eton SolarLink FR360 AMFMWeather Radio
Put batteries in, tried cranking it. Only light works. Nothing else will turn on. What can I do?
Truck wont start
Starter fluid won't work if the starter won't turn the engine over.
Get the battery load tested...it may not have enough juice to start the truck but have enough to light up the lights
check your fuses and battery connections at the starter. Is the anti theft light flashing? If it is that's your problem. Wait 10 minutes insert the key...wait for the theft light to go out before trying to start.
if that doesn't work you will need to get the starter checked...which means you will have to take it off.
Sep 01, 2016 | 2001 Oldsmobile Bravada
1996 Buick Regal turned off put gas in would not start makes no sound when you turn the key no click nothing tried all the tricks any idea whats wrong
make sure car is in park or neutral, if still nothing, make sure battery terminals are clean, just because the dash lights work does not mean there is good enough connection at the battery to start the car. Make sure battery is fully charged. If still nothing, sometimes giving the starter a tap with a hammer will get it going again. Good luck.
Mar 02, 2015 | Buick Regal Cars & Trucks
Will not turn over
If the lights work but no crank, it could be the security system or the neutral safety switch among other things.
Is the security light on or flashing ? Do the warning lights come on when you turn the key on ? Did you try cranking it in neutral ?
Jun 02, 2013 | 2001 Oldsmobile Alero
97 dodge neon turn key have lights but no crank or no noises
Is the car still in gear? If it is, then it will not start till you put the car in park. I've done this before and the same thing happened, had radio, lights etc...till I put car in gear and it started. Check the gear selector, if it's not in park, then put it in park and try to start. Hope that helps.
Feb 20, 2013 | 1997 Dodge Neon
My 2000 lincoln ls doesn't crank or click when trying to start it, it does nothing? all the lights work, radio, signals and horn, I checked the fuel relay and the starter relay and the ignition fu
Sounds like an Ignition Module or similar device. Does it have an alarm? Turn the key to ON - not start - and put into Drive and then back into Park. It may be the shifter isn't fully engaged. Also, w/your FOOT ON THE BRAKE shift to Neutral and try to start it.
GL,
Td
Oct 01, 2012 | 2000 Lincoln LS
My 94 Buick Century wont start? Trying to figure out if it is the starter...I hear fuel pump engaging light and everything work. when I go to start does nothing...
Check your battery voltage, sound to me like your battery cold cranking amps is low. Its enough the power the lights but not turn the engine over. Have the battery replace
Jun 06, 2012 | 1994 Buick Century
This morning tried to start my 03 sierra 1500, i opened the driver door cab lights came on, put key into the ignition turned the key and the lights went out and the truck would not even crank nothing....
Try jump starting it. I suspect your battery is dead. After time they don't hold a charge as deep as they once did. Have it load tested to verify. Your lights and other options don't draw nearly what your starter needs.
Mar 10, 2011 | 2003 GMC Sierra 1500
1989 ford truck f350 diesel. head lights,hazard lights, and horn have power and work, batteries are charged but truck will not crank. when i put key in and turn the key over nothing happens....no buzzer,...
1989 f250 4x4 lighting problems. i replaced the floor mounted dimmer switch ,the lights worked fine for an hour untill i turned them off.Now the lights will not turn back on but i have park lights.
Aug 09, 2010 | 1989 Ford F 350
1997 VW Jetta will not start and battery is good
You need a new ignition switch, the electrical part of the points in the switch have burt out.
May 12, 2009 | 1997 Volkswagen Jetta
1999 Pontiac Grand Prix Won't Start
if battery cable and starter is good . key entry security mode is on or going bad .try another car key .if cranks that it if not. put key in ignition. turn the key to on position .for 10 minutes. dont touch nothing if security lights off turn switch off for 5 secs.if starts your .security body control module or ignition switch is bad that a dealer ship job .have to have tech 2 scanner to reprogram it to crank.
Mar 10, 2009 | 1999 Pontiac Grand Prix
Eton SolarLink FR360 AMFMWeather Radio Logo
118 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
David Burbee
David Burbee
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
