Question about Garden
It starts but no output - Garden
    Scholar:
  • 54 Answers
If it starts but there is a sound of resistance when you throttle up and no chain movement, then the chain brake system where it circles around the centrifugal clutch has fine sawdust accumulation. This acts as a brake even though you click the chainbrake to the run position. You have to remove the two bolts, the side cover, the chainbrake unit itself and get all that dust out so that the centrifugal clutch with the sprocket on it will spin while the chainbrake ban has just a bit of clearance. This has to be a fine clearance because it has to stop the saw in an instant, usually saving your lower leg from getting chopped into when walking along (and slipping off) a log while limbing.
Posted on Mar 26, 2011
08 pont grand prix 5.3 no start,no eng.light on but code reads po341
No start ???? No crank - no start or crank no start ? Meaning when you turn the key to start the vehicle what happens ? Does the starter engage an spin the engine or not ?
DTC P0341: Camshaft Position (CMP) Sensor Performance
The 4X camshaft position (CMP) sensor circuits consist of an engine control module (ECM) supplied 5-volt reference circuit, low reference circuit, and an output signal circuit. The CMP sensor is an internally magnetic biased digital output integrated circuit sensing device. The sensor detects magnetic flux changes between the peaks and valleys of a 4-tooth reluctor wheel attached to the camshaft. As each reluctor wheel tooth rotates past the CMP sensor, the resulting change in the magnetic field is used by the sensor electronics to produce a digital output pulse. The sensor returns a digital ON/OFF DC voltage pulse of varying frequency, with two narrow, and two wide output pulses per camshaft revolution that represent an image of the camshaft reluctor wheel. The frequency of the CMP sensor output depends on the velocity of the camshaft. The ECM decodes the narrow and wide tooth pattern to identify camshaft position. This information is then used to sequence the ignition timing and fuel injection events for the engine. The ECM also uses CMP sensor output information to determine the camshaft relative position to the crankshaft, to control the CMP actuator if equipped, and for limp-home operation.
Do you know how to test engine sensors ? Videos on youtube .
Jan 30, 2018 | Cars & Trucks
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Wont start
check the ignition switch. pull covering off of the column and check switches wires,
reds - should have +12 battery power
white - Ignition output
pink - ignition output
yellow - starter output
these wires are needed to start car.
from the switch the starter wire goes to and neutral position switch. located on transmission. yellow is starter in purple is starter output. if all that is good change the relay moun about the radiator. good luck
Sep 24, 2009 | 1998 Chevrolet Cavalier
Do not start when start button is pressed. Seems power adapter K30266 is defective. Output should be 24V, but I get only 7.2V.
power adapter is definitely defective if it only has 7.2 volts on it output. check if you have plugged it in the correct voltage!
May 21, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 01, 2009 | Python Vehicle Parts & Accessories
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
