Question about Bosch Brute Breaker Hammer 11304
@runs hot motor feels slow doesnt hit hard - Bosch Brute Breaker Hammer 11304
    President:
  • Bosch Master
  • 1,388 Answers
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered and properly lubed. If not powered correctly, motor will not turn at full rpm, get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. If you are sure that it is getting proper voltage /amps then may need lubrication or bearing work. Remove bearing cover and turn armature by hand. It should be easy to turn. If stiff, suspect bearing/grease. With amp meter connected, check amp draw and compare to rated amps.
Posted on Mar 26, 2011
Why does my 2006 Pontiac Montana feel like it kicks at 20-40 mph? - insert more words for faster question answering-
sounds like a bad motor or transmission mount try to step on the gas hard and release it quickly while in park do you feel the same thing if you do a motor mount is no good you'll see the engine twisting or raising up on one side the reason why I think its happening at slow speed is the transmission shifts gears and this lets the motor settle back down if not try with no body behind you quick acceleration then wait 5 seconds and hard stop when the car is stopped and you feel a bang from underneath the transmission mount is no good
Aug 23, 2014 | 2006 Pontiac Montana SV6
No heat when vehicle hits running temp
NO year Wangler makes this hard..... no year, no joy. sorry/
engine at 180F and holding, that is step 1
step 2 is, the blower fan runs on high, at full speed
yes/no?
and last , if the heater core is hot (feel it)
then the dampers are wrong.
on my 08 i feel the 2 hoses on the core as they pass through
the fire wall, are they roasting hot (180F)
then if air passes through the core,said air must get hot.
if you feel nothing at vents, in all modes, the main TEMP. damper
is stuck closed, (this is the red and blue knobs)
the 10steps that work on any car, they all have a heat exchanger.
http://www.fixkick.com/AirCond/heater.html
Feb 10, 2014 | Jeep Wrangler Cars & Trucks
Ign timing 16.5 b/s motor mtd ride on. or cyl has fuel in it on cold start.ok most times on hot run ,can still play up at times
You cannot alter the ignition timing, it is set by the ignition unit and the flywheek key, if it has sheared the key it will knock the timing out, if the valve clearances are not correct the auto deco valve in the engine will not work and will increase the compression to the point where the starter motor cannot crank the egine over.
Mar 29, 2012 | Garden
It runs just fine, then you get on and it slows down almost to a stop.
This means that the motor is having to work too hard to rotate. It could be one of a couple of problems. If the machine is old then it potentially could be the motor itself. it may be going bad. On most models the motor has a lifetime warranty so you can check your owners manual for that. If you have not lubricated your walking belt in over 3 years or so then it could simply be a lubrication issue. To check this stick your hand on the underside of the walking belt and feel the belt. It should feel like a screen door. If it is smoothed down then there could be too much friction that is not allowing the belt to turn. When you pull your hand it should feel like you have been eating popcorn, kind of oily.
Mar 11, 2010 | Proform Quick Burn Pro Treadmill with 12...
The hot air won't circulate to upperstairs
2 possible causes. 1 there is a blockage in the ventilation system (possible collasped ductwork) or 2 the fan motor is going out. The motor could be going out due to the winding swelling as the motor is run heating the winding causing the windings to swell slowing the motors rpms.
Dave
Feb 22, 2010 | Bryant 463AAC005BA Air Conditioner
1997 suburban 2wheel drive when i put it in drive doesnt want to
Unless you have run over something or something has hit the linkage that you may possibly repair to adjust the gear locations to their proper place on the trans, you must get trans checked out.
Dec 11, 2008 | 1999 GMC Suburban
Bosch Brute Breaker Hammer 11304 Logo
538 people viewed this question
Top Bosch Hammering Experts
John Trevino
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
