Question about Dell Inspiron 1501 Notebook
I can hear people on msn but people can not hear me
    Sergeant:
  • 236 Answers
The Dell Inspiron 1501 has a set of internal speakers but doesn't have a built-in microphone. You need to plug an external microphone into the microphone jack on the right side of the notebook as shown below. You can open Messenger and click on the Tools tab then select Audio and video setup. (note as there is no built-in webcam, it will just be an audio setup). You may decide later to add a USB webcam with a built-in microphone in which case the plug-in external microphone will no longer be required.
Posted on Mar 26, 2011
    Sniper:
  • 75 Answers
This is a common problem.
  • Check if your microphone setting is done properly
  • Make sure your recording volume is set properly (Follow audio config wizard)
  • If you have a low bandwidth connection may cause the problem if your uplink is too small
My webcam is built in on my laptop and people on msn can't see me but i can see myself and them. They cannot hear me either.
There is no longer a program called MSN - for nearly 6 years! The only MSN software now are Trojans, however there is still a MSN Web Portal to access Hotmail accounts.
Download Windows Live Messenger and use the built in configuration utility when you set it up.
Sep 12, 2011 | Advent Modena M101
Webcam and webchat problems on msn
Check whether the webcam is working.
Try reinstalling/updating the webcam driver.
May 31, 2010 | Microsoft LifeCam VX-1000 Webcam
When I make a call on MSN Messenger I can't hear the other person properly, the voice is very distorted. They can hear me clearly,and when listening to You Tube, all ok, comes over fine, either with...
try seeing if your friend is making the disortion on purpose for example try a diffrent audio chat with another friend on msn if its still disorted reinstall your sound driver
Apr 09, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
VX 6000 webcam
HI,
Please reinstall your camera drivers.If you still face the problem then reinstall msn messenger.
This should fix the issue.
if you need any more help let me know.
Thank You
Sep 12, 2009 | Microsoft LifeCam VX-6000 Webcam
Hi i have a hp dv 9000 lap top comp and i was talking to my family on msn live. i could see them throught the built in camera what do i have to do to hear them do i have to press f2 video clip
Make sure your speakers work and maby you have the sound muted on your msn window ....you may have to set up sound through msn in the tools tab i think.
Jan 06, 2009 | HP Pavilion dv9000z Notebook
Video sound problem
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Apr 05, 2008 | Logitech Quickcam Chat Webcam
No sound
When I video conference in MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer Test the Microphone in Sound Recorder
Mar 31, 2008 | Logitech QuickCam Chat Personal Web Camera
No audio
hey there, what you can do is update your msn messenger to the latest edition and try to re install your sound drivers. this may reslove your problem.
fixya!
Jan 29, 2008 | Logitech QuickCam 961464-0403 Webcam
Dell Inspiron 1501 Notebook Logo
98 people viewed this question
Alun Cox
