Question about Watches
How do i change the date on my Perry Ellis Ape 8059?
American perry ellis how to change battery
Take your Perry Ellis watch to a jeweler to have the battery replaced.
Dec 28, 2017 | Watches
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
Sep 16, 2011 | Tissot PRS 200 Wrist Watch
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
Jul 02, 2010 | Festina 6503-I Watch for Men
I cannot replace the watch back on my Perry Ellis watch
A watch press will be needed.
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
May 14, 2010 | Nixon Manual NIX0031 Wrist Watch
My Maurice Lacroix "Crystals Saphire watch # 8059; #67419," will not, manually, changeanything but "Time". Day and Date will not move. Cannot find "instructiions". PLEASE...
I tried to Contact Different Vendors as well as searched Different Websites and Forums, However, i do not see any Manual available for this Model. The only option would be to Contact Local Supplier or Manufacturer to get the Manual, if available.
http://www.mauricelacroix.com/#FIND%20A%20RETAILER%20OR%20A%20SERVICE%20CENTER
You would be able to Find the Closest Retailer, Distributor and Service Center.You could Contact them and Request the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 22, 2010 | Maurice Lacroix Watches
Help changing the date on my HYPE wrist watch The watch didnt' come with any instuctions. I don't know how to change the date. I have it on the correct day of the week but I can't change the date?
The date may have a mechanical change at midnight(ish).
f this is the case, take the watch past midnight and then wind it back to (say) 11 and then forward again. Repeat this until the correct date is achieved.
If you watch is an electronic type then press the mode button until the date change function appears (it is likely to be abreviated "DC ? perhaps" and then use one of the other buttons to advance or ****** the date as required. Some experimenting may be required.
Feb 15, 2010 | Watches
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
Feb 03, 2008 | Seiko SNA553 Alarm Chronograph
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Watches Logo
312 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
