Question about Soyo DYLT032D 32 in. LCD Television
I have a soyo DYLT032D LCD tv that comes on and immediately goes to a black screen with a grey box in the corner
  • nejix13 Mar 26, 2011
    I can't check inputs because as soon as i turn on the tv i can get the menu to pop up for a few seconds, but there are no words in the menu, then the grey box just pops back up
  • 902 Answers
Check your input settings on the cables make sure they are in right and the tv is on the right input otherwise you may have a bad screen
Posted on Mar 26, 2011
  • brian shevack Mar 26, 2011
    unplug tv for about 5 minutes this will reset the tv and back to a normal state and drain all the capacitors of any juice left in them if the issue is still present after researching your model i have noticed others with the same issue and they all had to replace the mainboard for it which cost upwards of 400 dollars
How do i connect my directv box to my soyo tv #DYLT032D
  • If your DirecTV box supports HDTV then connect it using either an HDMI cable from the box to the TV (located on the back, labeled HDMI 1,2,3,etc.).
  • If the box is not an HDTV box then connect it with a RGB (red, green, blue) composite cable from the box to the TV.
  • If the RGB output is not on the ack of the box then connect using a standard coaxial cable.
[NOTE] In order for the quality of the picture to be HD, use the RGB for digital (Better), or the HDMI for High-def (Best)
Mar 02, 2011 | Soyo DYLT032D 32 in. LCD Television
TURNIG ON THE UNIT THE SOYO NAME COME IN JUST A SECOND AND IT GOSE BLANK ( BLACK SCREEN BUT THE SOUND IS ON )
I came across the same problem and i replaced all the capacitors on the power board and that fixed it. but now it came back with bad ccfl tubes backlight. hope this helps.
Oct 31, 2010 | Soyo DYLT032D 32 in. LCD Television
My Soyo TV sudenly wont turn on, complete black screen, no sound.
enciende despues de cambiarle los filtros de la fuente ppero tengo rayas en la parte de el horizontal que tengo que n hacer y remplazar tendran ustedes los repuestos
Jun 01, 2010 | Soyo DYLT032D 32 in. LCD Television
Need power supply part for soyo fsp230-5zm01
Soyo DYLT032D has sound but screen is black no backlight.
Nov 20, 2009 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Oct 29, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv only turns on, will go to soyo screen then black screen. when you can get the menu it only has symbles and no words can not turn off with out unplugging. never has a picture
Sounds like the Main Mother Board is the problem. Basically, it's the brain inside the TV. Controls and functions is that board's job.
Soyo parts are hard to come by. You can try running the number off the mother board on the internet and maybe a supplier will pop up.
Their Soyo.com web site isn't working. So, I'm thing they maybe out of business.
If you have some electronic experance and if your lucky, the heatsink on the chip processor is the problem.
Aug 05, 2009 | Soyo DYLT032D 32 in. LCD Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
Remote codes
whats the code for the soyo tv universal remote
Dec 29, 2007 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLT032D 32 in. LCD Television Logo
125 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
