My samsung tv model PS42C91HDX/XSA will not turn on. It clicks as if it is about to power on then turns off repeatedly every 3 seconds or so.
  • 81 Answers
SOURCE: TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Posted on Dec 15, 2006
  • 4 Answers
SOURCE: Samsung LE40R7 LCD TV Attempts
Possibly due to the main inverter panel, take the numbers off and price one up they vary from £50 upwards
Posted on Apr 08, 2009
poacher1
  • 10 Answers
SOURCE: Continuous click noise like its trying to turn on but will not.
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
Posted on May 13, 2009
  • 7 Answers
SOURCE: My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
lightnbaby
  • 36 Answers
SOURCE: My Samsung LCD has no picture (screen is black)
open back cover check 5v filter capacitor on powersupply board that is either 1000uf or 2000uf
do you see any bulging capacitor? replace with top quality capacitor.
Posted on Aug 07, 2009
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
? 4:41
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung PN50C590G4F plasma TV turning on and then off with clicking sound after 6 seconds
Have you tried replacing the power cord or the voltage feed may be off replacing the whole cord should correct that
Jan 02, 2015 | Samsung PN50C590 TV
The tv wont turn on but keeps turning on and off byitself continuosly but not suceeding
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 07, 2012 | Samsung Televison & Video
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
My samsung ps42c91hdx/xsa tv wont tune in the high def channel 10. the tv can't find it. My sons tvs are picking it up so it cant be the signal.
go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
May 06, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Tv just turns itself off and then starts clicking like its trying to turn on and off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 03, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
