Question about AMD Asus A8V Deluxe Socket 939 Motherboard K8T800Pro Retail Boxed (MBSK939ASA8VDX)
Monitor is not recognized. - AMD Asus A8V Deluxe Socket 939 Motherboard K8T800Pro Retail Boxed (MBSK939ASA8VDX)
  • AMD Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 26, 2011
Sony SDM-HS53/HT 15 in. Flat Panel LCD Monitor. I have using the monitor for a long time. I just bought a computer (not a laptop). The monitor is not being recognized. What's the problem? The monitor is...
get the mane and model of the monitor go to the manufacturers web site and down load and install the latest driver for the monitor that matches your operating system on your new computer .
I hope this helps Andrew A
Apr 12, 2011 | Sony SDM-HS53/HT 15" Flat Panel LCD...
MY TOSHIBA SATELITE A200 - TH1 LAPTOP WILL NOT RECOGNIZE MY SAMSUNG 2243BWX MONITOR THIS MORNING. I HAVE CHECKED THE CABLE AND UNPLUGGED IT AND REPLUGGED IT REPEATEDLY. I HAVE A SECOND MONITOR FROM...
look on keyboard you will see two symbols of monitor in a single key which may be from f1 to f10. connect monitor and press that key laptop will recognize the monitor
Feb 02, 2011 | Samsung 2243BWX Monitor
The windows 7 is not recognizing the monitor VA721
May I ask what you mean by the windows does not recognized the monitor? You are not getting picture or you cannot set the correct native resolution (that is the best setting for best picture and aspect ratio)?
Native resolution for this monitor is 1280 x 1024 @60Hz.
And here is the common problem with VA721: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Mar 31, 2010 | ViewSonic VA721 17" LCD Monitor
Monitor not recognized
You have to go to graphic software on computer and manually select extended Monitor
Nov 23, 2009 | Syntax Olevia 327V 27 in. LCD Television
PC not recognizing monitors or keyboard
Try flashing the bios, which is found as step 3 on the flowing website. here.
If that does not work, make sure the connectors are not damaged, and ensure that all internal components, especially power cables, are properly seated.
~gnome
Jan 04, 2009 | HP Compaq Presario SR2150NX PC Desktop
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Jul 27, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
Dec 13, 2007 | Microtek C593 15" Flat Panel LCD Monitor
AMD Asus A8V Deluxe Socket 939 Motherboard K8T800Pro Retail Boxed (MBSK939ASA8VDX) Logo
32 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
