Question about NetGear WGR614 Wireless Router
Router disconnects when wireless computer connects
I have a modem, which Comcast says is fine and the signal is fine. A couple days ago, I could not connect to the wireless network. So I reset the router like normal, and the connection is fine.... until the 2nd computer upstairs, that connects wirelessly (also a Vista, blecch) connects to the network.
It will be on for 30 seconds to a minute and then it disconnects, and says it has limited access. And then the main computer cannot connect either.
I have had this whole setup for 5 months without problems - and I didn't make any changes. This happened all of a sudden.
  • kanlala Aug 04, 2008
    When the modem is connected directly to the main computer, the internet connection is fine.
    So that leads me to believe the problem lies somewhere between the modem and the router. Yesterday I reset it again and it worked for about one hour before it bombed out the same way again.
    How do I update the firmware? And where do I find it? I don't see a reference to any of this on the site.
  • 144 Answers
i have the same problem before and i called supportrix and here are some tips that may also help you solve ypur problem
-- are you experiencing the same problem if you connect your computer directly to the modem? this may help you isolate if its a problem with your router or with your modem / isp
-- have you tried upgrading the firmware of your router? this may help you fix other internal problem on the router aside for upgrading the current settings of your router.
-- do you have other devices running with the same freqeuncy of your router? chances are that you may also encounter some interference on the wireless part of ypur router so make sure to disable these other devices
if you are still having trouble configuring your device, try to call supportrix
Posted on Aug 04, 2008
Computer Will Not Power Up
I don't quite follow your question? My mergers? My wireless things? If you are referring to laptops/Desktops, connect a Ethernet Cable directly to the Comcast Modem. You can call Comcast to verify the signal and sent a fix signal, basically a reboot, which you can do by removing ALL power from the modem and wireless and replace battery, plug in the Modem, wait for selftest, plug in the wireless device, wait for selftest, try again. As to the Computer not powering up, that's another issue.
May 10, 2013 | Computers & Internet
I have comcast cable and internet but my cords wont reach to where my computer is, I also have a wireless linksys adater on my hard drive. Am I able to connect to my comcast modem with this?
That depends on what comcast modem you have. If it has an integrated router, yes. If it is just a modem not. Simply spoken, a modem just converts your computer's digital signal to whatever is on the other side, usually analog. It doesn't do what a router does - routing the signal.
Just reply to this post and let me know what model of modem you have and I can give you a definite answer.
Jan 07, 2013 | Linksys Wireless-G WMP54G 802.11g/b
At least once a day I have to re boot my router so my wireless gear can pick up the signal. Why?l
After checking ALL cables and reseating connections, checking for bent pins, Contact Comcast have them analyze the signal. And have a Comcast Tech come out and trace the signal through the house. It may be outside. I had a similar issue, the problem was outside, a underground box had been run over by a big lawn mower damaging the box allowing water to enter.
Dec 28, 2012 | NetGear N300 Wireless Router
I installed my D-Link DI-784 six days ago. It's connected to a Dell 8100 running Windows 7. It worked fine until an hour ago, when it stopped broadcasting. The router is connected to a DSL modem. If...
It is possible that a neighbor purchased a wireless access point that it on the same channel and they are competing. Change your wireless channel. You could also try a hard reset. Instructions at D-Link's website. Good luck!
Apr 08, 2011 | D-Link (DI-784) Wireless Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Xbox live stops working
It is a conflict with your router and modem. If you have a WRT54G linksys router and a Ae60 modem then this conflict will happen. To stop it, buy a new modem or router OR connect to XBox LIVE wirelessly using the XBox 360 wireless adapter ($100).
Jan 05, 2009 | Microsoft Xbox 360 Console
Network switch
Sounds like you know what you're doing... but.. based on what you've typed..
You need to make certain the comcast cable modem is plugged into the seperate port on the back of the router called WAN and not next to the other LAN connectors.
The network is seperate from the internet. The router acts as a firewall and shares the WAN with the LAN internally and automatically.
I assum that you have one red light on WAN.. and three green lights for LAN..
Jun 18, 2008 | Arris Wireless G Broadband Router (wr850g)
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at
Feb 03, 2008 | 2wire (1000-400108-001) Router
Internet will not connect through router.
Hello Orionj2
We can provide you with the best Comcast internet tech support, so if your Comcast internet is not working fine, then you just have to get in touch with support. Call us today and get internet related issues fixed.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
Sep 20, 2007 | Belkin (F5D5231-4) Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
