Even if the power cord and data cord is attached ,still i cant access my hard disk.
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 26, 2011
My nc6400 won't power on even when connected to the power cord
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Aug 17, 2012 | HP Compaq nc6400 (GJ982US) PC Notebook
My laptop can detect my hard drive but i cant access the files in it
you can recover files from hard drive with asoftech data recovery program. download the program from
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 27, 2011 | Computers & Internet
Hard disk transcend 250 gb storejet isnt oening and not even detecting in vista and windows 7 and also in xp how could i open it
You may just using just a data usb cable on your hard disk. Try to get usb cord with data and power cable (combo) and check if this resolves your concern.
Hope this helps.
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I replaced the hard drive because of the click of death. When I booted the cpu, I got a error message saying, system boot failure, install disk press enter. I place recovery disk in and disk started to...
You should check if your PSU is providing enough power to the hard drive. In case the hard drive requires more power, you should either replace it or get a better PSU.
Consult a professional for best results.
Jan 01, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
I have 3 2TB lacie bigger disk triple interface. I use them to backup my data. Unfortunely I lost 2 power supply so I used one for all. Yesterday I backup up all my data on one disk, I unplug this and...
If the power supply doesn't delivers the correct current the hard disks can't spin fast enough and this is detected as a failure by the pc, which cuts the connection. Hopefully by replacing the source all will go back to normal. Otherwise you will have to crack open the cases, remove the disks and install them directly in a desktop to try to access the data on them.
Dec 14, 2010 | LaCie Bigger Disk Extreme 2000 GB Hard...
I have been using Seagate FreeAgent on this dell laptop with Windows XP for about 2 years now. But since last evening, i am unable to detect it on my computer. The freeagent is plugged on, the orange light...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive. Seagate's web-site has an data-recovery offer: no charge if we cannot recover your files.
Nov 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My aspire l310 won't boot. It keeps telling me media cable test failure and disk boot failure. Help daniel
sounds like hard disk related. turn it off and disconnect the power cord, remove and reconnect both the power and data cables to the hard disk, disconnect any external USB storage and remove any floppy disk, if any. If you get the same result, try to connect the har disk using different power & data cables (IDE/SATA), and test it on another SATA channel if available. If same error, you may need to reformat the hard disk and reinstall WIndows, or you may have to get a new Hard Disk if it fails even when tried on another computer.
Aug 31, 2010 | Computers & Internet
Failed to boot, i cant even get to the bios! only the fan running, led(green) and (red) indicator doesn't even light.
Dear Client, unpluged all the data cables, power cables or wires, bios cell and RAMs. Everything should be unpluged from the motherboard for two hours and then reassmbled. It will work properly but when you reassembled it just plug with the follwing devices.
* Power Cables
* Data Cables
* Bios cell
* Processor + Fan
* RAMs
Do not attach CD-Rom or Hard Disk, just turn on the computer without Hard Disk and CD-Rom and try to enter in bios setup. I assure your problem will be solve. Now you can attach the CD-Rom and then try to boot up from the CD-Rom and in the last you should try to attach Hard-Disk. I hope you will do it step by step and get success.
Good Luck
Feb 14, 2010 | Asrock 775i65G Motherboard
Hard disk no open
Hello, may b your other harddisk mite hav sum errors in it. Hope its detected in windows, bt not accesable.
Try booting with any linux live CD (google "puppy linux", its just 90MB approx) and connect the harddisk. Now access ur harddisk from linux. If u still cant access it, then u should format it.
if it works in linux, then backup all ur improtant data and format it wit NTFS. Ur prob shud b solved!!
Jun 22, 2009 | Video Game Consoles & Games
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
