Question about Panasonic NV-GS230 Mini DV Digital Camcorder
I BOUGHT A FIREWIRE 4PIN END TO END FOR MY CAMERA. CONNECTION FAILED. COMPUTER DOES NOT DETECT MY CAMERA
    Sergeant:
    Champion:
  • 269 Answers
Open Windows Movie Maker and have the camera set to VCR mode, that's the one thqat replays the tape.
Try again.
Posted on Mar 26, 2011
I have a SONY HandyCam DCR-SX44. I want to transfer video/audio directly from the camcorder to Windows Movie Maker. I have a cable with USB connection on one end and 5 pin connection on the other, but...
I had similar problem with my Sony Digital8 (also called HI8 ) handycam. My vista system was not able to detect my Handycam with a very very cheap FIREWIRE PCI Card I bought in local market for only $4, yes four dollars. It came with 6pin to 4pin Firewire cable(Sony calls it i.Link). I was trying to connect with same cable 4pin at camera end and 6pin on PCI Card, with no luck. It was even showing DV-IN on camera LCD with this 6pin to 4pin cable. I tried everything an expert would do, but got only frustration. Even tried a lot on Internet for the solution but it seems no one knew.
Then I started from scratch, TO DECIDED TO READ MANUAL. While reading the PDF manual found on Sony Support site, trust me, I found those golden words "USE ONLY 4PIN TO 4PIN i.Link Cable for Firewire connection."
I ran back to market and bought 4PIN TO 4PIN Firewire Cable for $1.5
At first trial, trust me, it detected "SONY DV Camcorder" and installed drivers automatically. I confirmed by going into Device Manager and found same entry in Imaging Device section. Then what in every possible software existed on my system, DV Capture was available, which was found always disabled.
Now the funny part it, technically there is no difference in 6pin to 4pin Firewire cable as two pins are used for Voltage which is discarded at 4 pin end. But it seems SONY Handycam does not wants itself to connect it to 6pin socket at PCI card end.
So these are the final things to remember.
1) Use only 4pin to 4pin Firewire cable (any cheaper make. $1.5 will do)
2) Use any cheaper FIREWIRE PCI card with at least one 4pin firewire socket. When installed XP or Vista will install driver automatically just confirm that "IEEE 1394 bus host controller" entry is shown in Device manager or not.
3) No matter you use cheaper or costlier PCI card or cable the quality will always be same coz D8 Handycams directly transfer encoded Video Data in Digital format thru Firewire cable. Firewire cable does not transfer RF video input. I get default video with 720x576 with 25 Frames/s in PAL mode.
4) No additional codecs are required to install in pc like others suggested. Required codecs are always there in XP and VISTA with windows movie maker.
5) No additional software is required, as you can directly capture with Windows Movie Maker in high quality. My choice is Adobe Premier CS3. If you want to make directly MPG file you may use ULEAD VIDEOSTUDIO 8 or later.
6) Do not blame non.gif SONY as they already told you which exact cable to use.
7) Do not blame non.gif Vista. Its nothing to do with it. Sony's PicturePackage for XP does not work on vista. For vista they offered PICTURE MOTION BROWSER which also have easy VIDEO Capture utlity with same high quality capture. Some people falsely claim that "VISTA DOES NOT WORK WELL WITH FIREWIRE" That is completely wrong. See, one or few people may have problem and they always keep shouting for thier fate. But it actually it could be thier local hardware or software problem or anything. There could be many reasons at the same time too. Many people even do not care to change to new cable and keep trying on same thing. Actually cables are very delicate rubber material. Many a times you get faulty cable in new petty pack box of devices. Or it could be some firewire chipset problem too. Last is driver problem. Many firewire card manufacturers have not yet made stable drivers for vista. Most problems are solved if newest drivers are downloaded and installed.
7) In handycam mode, you can control PLAY/STOP/PAUSE of Handycam from PC itself from all the video software you use, which is high convinience for capturing.
8) My sureshot capture sequence is as follows.....
a) Remove BATTERY from camera and switch on with AC Adaptor
b) Put it on PLAY/EDIT mode (also called VCR mode).
c) Connect 4pin to 4pin firewire cable on camera side and in firewire PCI Card. Now you see the words DV-IN on LCD of camera, if LCD is open.
d) Now start any Video Capture Software of your choice. You will find CAPTURE command in FILE menu in almost all softwares.
e) Enjoy.....
Jun 26, 2011 | Sony Video Cameras
WHICH FIREWIRE CABLE DO I GET FOR THE SONY DCR-TRV22E DV
you would need a ieee1394 4pin cable for the camcorder. of course the other end of the cable would depend on the computer's ieee1394 jack you'll be connecting the cable to. there are 2 types of ilink cables: 4pin-to-4pin or a 4pin-to-6pin (firewire 400) cable. latest mac computers uses a firewire 800 port so if your using one you may need a Moshi 800 to 400 firewire adapter if your having compatibility issues. see: http://store.apple.com/us/product/TW748LL/A for more information. hope this helps. thanks:)
May 29, 2010 | Sony Handycam DCR-TRV22 Mini DV Digital...
I have a sony pc 100 dv cam. I am trying to find the right cable to connect it to my mac. I need what ever sony uses one one end and usb on the other.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
Mar 11, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
My computer does not detect the camera, I have turned it off and on again, I am using a firewire etc. what could be the problem?
It should be detecting .. else try this... I hope you are using the 4 pin to 4pin firewire cable which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Dec 18, 2008 | Panasonic PV-GS32 Mini DV Digital...
Panasonic NVGS60 mini dv camcorder
Hi!
I have had the same experience with the same laptop. In my case, I went to Add New Hardware in Control Panel, and had my laptop automatically search for the connected camera. From there, it was automatic.
If this doesn't work, try restarting your laptop with the connections in place. Then repeat the above described procedure.
Hope this helps!
Nov 10, 2008 | Video Cameras
Converting video content to a CD/DVD through the computer
You need a computer with 1394 firewire card and a 4 pin to 6 pin firewire cable. The 4 pin end goes on i-Link connector on camera end the other end of the cable on the computer card. If you have a notebook, will you need 4pin to 4pin firewire cable.
Nov 03, 2008 | Sony Handycam DCR-PC105 Mini DV Digital...
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
Can I transfer to my computer
Based on the specs of your product yes you can as long as you have IEEE 1394 (FireWire/i.LINK) or a Video capture card like an ATI all in wonder or just a plan old capture card for the use of S-Video or Composite capture. Unless you have a laptop the your probably only going to have the IEEE 1394 (FireWire/i.LINK) option either through the one on the laptop or by way of PCMCIA Firewire for a laptop. Next you'll need the fire wire cable to go from one to the other. Make sure you gt the right combo on the end either (4pin to 4pin) or (4pin to 6pin) etc. Lastly you need some software to record like Vegas Video, Adobe Primere, or other **** programs. There are free programs out there too.
Just follow the instruction of which ever program you choose, and just record.
Hope this helps. M~
May 01, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
My GR-D77OU jvc camera
IEEE 1394 doesn't work like USB so it probably won't show up in devices. What you would do is go to a video editing/burning program and click on a capture video option. The program accesses the video camera and you can choose what video you wish to record onto your computer.
Apr 08, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Panasonic NV-GS230 Mini DV Digital Camcorder Logo
135 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
