I want to know how philip hr2304\70 ice mixer can be use when maknig an ice cream. what can one do so as to chil the ice cream
  • 32,281 Answers
You use ice to chill the cream container, add salt to the ice to lower the temperature further.
Posted on Mar 26, 2011
Replacement parts for philips ice cream maker 2302
The only ice-cream maker on Philips website is the HR 2304 - the replacement cooling block for this is HR3936/01.
See on this webpage:
http://www.philips-shop.co.uk/store/catalog/household-accessories/ice-cream-maker-accessories/-/productdetail/HR3936_01_GB_SHOPPUB/GB/en?active_tab=overview#productDetailtabs
Not sure if this will fit yours?
Otherwise explore the Philips website for contact/support.
Feb 21, 2013 | Ice Cream Makers
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Kitchenaid ie cream maker
    good day,
    hope this link below will solve your problem.
    kitchen
    Apr 26, 2010 | KitchenAid KICA0WH Ice Cream Maker
    I have a kitchenaid 5ksm150(UK), I recently purchased an
    Hello KELPIES52. I see you have two postings, with some minor differences. You say purchased an “ice-cream maker attachment” in the US and my first clarification question to you is, did you purchase the KA Ice Cream Maker, Model KICA0W, or some other brand that said it was compatible with KA mixers?
    If you did buy a KA ice cream maker, then it should fit all KA models, including yours. If you purchased another brand of ice cream maker, then it may never be truly compatible, and there’s the rub.
    First regardless of what brand of ice cream maker you purchased, you should have both your KA mixer’s Parts List manual and both the KA Ice Cream Mixers Parts List and Users Manuals in hand. If you're lacking them, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
    Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use 5KSM150, for you mixer and select the file 5KSM150PSEWH4.pdf (777.26 KB) listed under Parts List (1113) (you can actually choose any file sized 777.26 KB; they are all for the different color UK models) and then check to verify this matches your mixer model. This is a good file to have on hand if you ever decide to troubleshoot and fix your mixer by yourself.
    After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List and the Use & Care Guide manuals (even if you don’t have a KA ice-cream maker) for your future reference.
    If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer's agitator shaft. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
    On the other hand, if your ice cream maker is not a KA model, you can still remove the collar, spring and groove pin if you’d like to give it a try. You will need a punch drive with a smaller diameter than the groove pin, a hammer, steady hands and plenty of patience. Tilt your mixer’s head up and rotate the planetary agitator shaft so that the flush end of the pin with the agitator shaft is facing you (the extended part of the pin is facing away from you). Align your punch drive on the end of the groove pin and give it a good whack; repeat until the pin starts to come out the other side of the agitator shaft. Continue tapping until the pin comes completely free. (Note the groves on the pin as you will need to orient the groove pin the same way when you reassemble the spring and collar on the agitator shaft when you’re finished making ice cream). Once the pin is removed the spring and collar will easily come off and then you can attempt to mount the ice cream maker drive on the agitator shaft. Caveat Emptor! Good luck, I hope this helps. Howard, Burke, VA
    If this solution has helped you, please rate it, thanks! - hslincoln
    Feb 22, 2010 | KitchenAid 32685 Mixer
    Have kitchenaid 5ksm150(UK),recently purchased an
    After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List manual and then the Use & Care Guide (even if you don’t have a KA ice-cream maker) for your future reference.
    If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
    I bought a ice cream maker from the US unfortuneatly the drive assembley isn't the right fit for my kitchenaid. Do you or can you help me find the right part? Kind regards Robyn Ricketts
    Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
    If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
    You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
    I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
    I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
    Jan 10, 2010 | KitchenAid KSM150PS Artisan Series Stand...
    Need the instrutions on the Black & Decker Arctic Twister Ice Cream Mixer
    hamilton.kijiji.ca/c-buy-and-sell-home-appliances-black-and-decker-arctic-twist-ice-cream-mixer-W0QQAdIdZ138713610
    Jul 06, 2009 | Black & Decker Ice Cream Makers
    Need to know how to use it and what to put into it to make ice cream
    This product is used to turn store bought ice cream in to soft serve with added treats.
    The Use & Care Guide for your Black & Decker IC200 Arctic Twister Ice Cream Mixer can be found here:
    http://useandcaremanuals.com/pdf/IC200203.pdf
    See page 2 of the pdf for instructions on how to use.
    Sorry someone has not responded sooner.
    Jun 28, 2009 | Black & Decker IC200 Arctic Twister 2.11...
    How do you attach the ice cream maker to the mixer
    I beleive that you need to have a bowl lift version to use the ice cream maker. Check you owners manual. If you do not have a manual, you can see it online HERE.
    Aug 18, 2008 | KitchenAid K45SS Classic Stand Mixer
    Attaching icecream maker
    KitchenAid Ice Cream Maker Attachment:transp.gif
    Convert any KitchenAid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all KitchenAid household stand mixers.
    Includes:
  • Double-walled Bowl
  • Churning Blades
  • Basic Recipes
    Instructions: The freezer bowl must be frozen for 18-24 hours prior to first use. Before each use, bowl must be completely frozen. Cycle time: 30-min. for soft-serve ice cream. For firmer consistency put in freezer for 1-2 additional hours.
  • Mar 02, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
     Grubhead
    Grubhead
