Question about Briggs & Stratton Garden
Briggs & st 16.5 smokes but runs well - head gasket ? smokes under load -heavly not at idle
4 Suggested Answers
  • 1111 Answers
SOURCE: no power/rough idle/black smoke
either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Posted on Jun 23, 2009
lester482529
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
philwalker78
  • 608 Answers
SOURCE: Briggs & Stratton twin with overhead valve engine.
Hi, check the engine oil level. It will be most likely over full as it has become contaminated with fuel, if so you will be able to smell fuel on the dipstick. If thus is the
Posted on May 05, 2011
Just replace head gasket & timming 2000 mit mirge it smoking now
If the head gasket was blown before,water will be in the exhaust system,If you had white smoke before ,give it time to burn out. I
Mar 19, 2014 | 2000 Mitsubishi Mirage
Bad intake manifold gasket?
Sounds like a blown head gasket.
Jan 03, 2013 | 1995 Buick Regal
How do you change a head gasket on a 16.5 hp briggs & stratton engine
Go to you tube and on the line type change head gasket on
16hp b&s.
Jul 13, 2012 | Garden
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
My 1994 villager starts, idles and revs fine After about thirty seconds a white galoline ladent vapor starts pouring from the tail pipe. It gets worse the longer it runs. Compression is good, the vacuum...
Bad head gasket & the white smoke is coolant
The O2 Sensor see the coolant or water vapor
& then PCM adds fuel
So you got coolant & too much fuel out tailpipe
Do a Combustion Leak Test where you put a plastic
container over the radiator cap area & see if the
blue fluid turns yellow indicating exhaust in coolant
from head gasket
Jun 14, 2011 | 1994 Mercury Villager
May 05, 2011 | Garden
1991 mazda 323 1.6 16 valves manual. the car has a rough idle, a miss. burn greyish smoke and water comes from the exhaust. it overheats quickly and the radiater loses water with no trace of where it...
You have either blown out the head gasket or cracked the cylinder head itself. You will need to remove the cylinder head and at a minimum replace the head gasket. Inspect head surface after dis-assembly to verfiy that no cracking is present.
Feb 18, 2011 | 1990 Mazda 323
2004 dakota 3.7l 2wd, overheated on the freeway running rough now and the next day it started exhausting a lot of white smoke when i started it and idled nroughly. It didnt overheat at idle but i didnt...
Sounds like a head gasket from your description. Look for coolant in oil (dipstick will look milky) If coolant is mixed in oil that would explain the rough idle (fouling plugs)
Jan 06, 2011 | Dodge Daytona Cars & Trucks
My 24 hp Briggs v twin smokes and uses oil bad. Smoke comes out of the left side when running. Can I use head gasket sealer to get me through the season?
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Oct 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
24 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
