Question about Hotpoint Microwave Ovens
I have a hotpoint over the range microwave that I am trying to remove. This unit is about 20 years old. How do I remove it?
  • Hotpoint Master
  • 9,086 Answers
You can download GE owner's manuals and installation instructions here.
Otherwise, GE Customer Service is here and they can point you to the proper manual.
Posted on Aug 08, 2008
Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
May 08, 2012 | Microwave Ovens
Trying to remove a microwave magic chef mvp iii -- about 20 years old
Try Magic Chef customer service here.
Oct 16, 2011 | Magic Chef CMV1000B Microwave Oven
It is running with funny noise and not heating?? It's about 20 years old. What suggestions do you have. It is an over the Jen Air range unit. Has the fan, etc...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ][
Jul 17, 2011 | Jenn-Air JMV8196 Microwave Oven
I have a 20 year old GE JCM140H over the range microwave which has always worked just fine. Last week everything just "died" no lights, no fan, no display, no microwave. I thought that I had...
You'll have to remove the cabinet cover to access the fuse. It is in line with the power cord. 20 Amp, slow blow.
One of the screws on the back of the cover may be a security TORX (the kind with a pin in the center of the head). Usually, if you tap on it with a hammer, you can remove it with a pair ov Vise-Grip pliers.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range microwave just stopped working while it was on. Is about 9 years old. Checked breaker and is on.
sometimes just the internal units fuse blows from age/use it is called a ceramic fuse,you need to remove the outer cover to replace this,carefully before touching anything inside the unit take 2 insulated screw drivers and discharge the hi voltage cap,then replace the fuse and try it,if it blows again,then suspect a shorted hi-voltage capacitor(especially if there was no arc during shorting it with the screw drivers) or a hi voltage diode shorted or the magnetron unit has begun drawing hi current or is also shorted
Mar 23, 2010 | Microwave Ovens
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
Removing a microwave
You can download GE / Hotpoint owner's manuals and installation instructions here.
Jun 28, 2009 | Microwave Ovens
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
137 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
