I have a fedders A24C1X air handler and i am replacing the transformer. i was instructed to buy a universal one which i did. i belive i figured out the wiring. my new ones common is white and the orange wire is for 240. the old transformer has a yellow wire hooked to the 240 and the the black wire i believe to be the common. my main issue is the wires coming out of the old one are blue and red and the wires on my new one are red and green. does it matter how they get hooked up? how do i find out which is which. i have a diagram on the air handler that tells me what the run to but not sure what the new ones are attached to.
  • Samuel Charles Spriggs Mar 26, 2011
    You are in the United States -- correct ?
    The tranformer's output is 24 volts AC -- is this correct ?
    Charlie
  • rubber_sled Mar 26, 2011
    yes that is correct
    President:
  • 1,489 Answers
First check the voltage on the red and green wires on the new transformer -- it should read 24 volts AC. If this is the case, the red and green wires would go to the contactor / relay 24-volt coil terminals -- wouldn't matter which one is connected to which side of the relay coil.
Charlie
Posted on Mar 26, 2011
Testimonial: "thank you so much"
My carrier programmablethermostat has no power
Check for power to the air handler.
If you have power there,check power on the low voltage side of the transformer in the air handler.
No low voltage out of the transformer is will need replacing.
There may also be a 3 to 5 amp fuse on the air handler control board that is blown.
Any auto motive fuse of the same size will replace it.
Apr 04, 2011 | Honeywell Heating & Cooling
I have a Fedders A24C1X, and I'm trying to figure out if it's a heat pump or not. I think it's an AC with an electric furnace.
Yep. It's got a 5KW electric heating coil in it. Telltale sign is that the first time each season when it starts up it'll smell like somethings burning until the dust on the element bakes off.
Jan 31, 2011 | Heating & Cooling
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2023.pdf
or this one...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2171.pdf
one of those should be pretty much like yours...
heatman101
May 06, 2010 | Carrier 38CKC036 Air Conditioner
We replaced our thermastat with a new one and it would notwork. replaced with the old one that had worked and now it does not work. is there a reset
Common problem with changing a tst. You blew the fuse in the furnace or Air Handler or you burnt up the transformer in the furnace or Air Handler. Hopefully you just blew a fuse. A 5 amp automotive fuse will fir back in the holder. Most all companies use a auto fuse 3 to 5 amp. Some have abreaker on the transformer. If you burnt out transformer you have yo replace it. Not hard to do Most of the time they 40 VA transformers. Go to HVAC supply house and buy one about 15.00
Dec 05, 2009 | Refrigerators
Our Fedders AirHandler Model#A24C1X keep 1 strip of heat when blower or nothing is on. have to unplug the red wire from NC on blower delay relay to stop it. blower relay Bd is new
Most of the time on Fedders unit one speed for heat comes off sequencer. This a low speed for heat. You may have bad sequencer. If your knowledge is limited about furnaces you may ahve to call service tech. But if you have some knowledge Replace the sequencer and follow woring diagram and you will be ok. Should solve problem. This time of year I replace dozens of sequencers due to this same problem. Rus
Nov 11, 2009 | Heating & Cooling
An Fedders mod# WFB1002 air handler has been hit by lightning and the fan runs constantly. Where can i find the part 052310 to fix it?
You can buy this part online at any ac parts website. You can replace it witha double pole double throw 24 volts realy. Rus
Jul 14, 2009 | Heating & Cooling
Will not power up
pedders air conditioning parts and service houston tx 713-661-1943 or try appliance parts reno i don't know if they deal fedders parts but they carry a bunch of weird stuff 320 S Rock Blvd
Reno, NV 89502
(775) 348-7733 u sure its supposed to be 10.5 volts coming out of the secondary.
May 27, 2009 | Fedders X Chassis A6X08F2A Air Conditioner
Fried transformer in air handler above board no #'s or voltage specs
What you need is a 24 volt transformer that has a rating of at least 40VA. 120 volts is the primary and 24 volts is the secondary voltage. You should try to figure out why the transformer burnt out first.
Paolo
May 05, 2009 | Heating & Cooling
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
