Intel Motherboard Logo
Posted on Aug 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Internet Connection Have had C:\PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL for a while and after looking at fixya have managed to remove by unchecking in startup box, but, before I did this have had problems connecting to the internet using ethernet connection to broadband box as my pc does not have wifi: I dial up the broadband connection, its says it is connected at 100mbps, and I can see data streaming when I look at Braodband status (showing sent and received) BUT, when I click on internet explorer it cannot finf the web page (google, microsoft etc). I have re installed the broadband software, outlook software, run Norton system works, run Ad-Aware,Reg-Cure and Spyware Doctor but nothing!!! Broadband on ethernet cable and wifi using same connections with my laptop is ok (same passwords etc) Can you help?
  • FloppyStick Aug 04, 2008
    kgjsm397
    thanks for the info unfortunately I got this reply from the ping and would need you to explain what you mean by 'change with firebox for testing'.
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Fletch>PING WWW.GOOGLE.COM
    Pinging www.l.GOOGLE.COM [216.239.59.104] with 32 bytes of data:
    Reply from 216.239.59.104: bytes=32 time=36ms TTL=247
    Reply from 216.239.59.104: bytes=32 time=35ms TTL=247
    Ping statistics for 216.239.59.104:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 35ms, Maximum = 36ms, Average = 35ms
KG John Justin
Level 2:
  • Expert 105 Answers
  • Posted on Aug 04, 2008
KG John Justin
Expert
Level 2:
Answers
105
Questions
Helped
95074
Points
251
Try to ping www.google.com , if no reply then there is problem in your broadband configuration.
if you are getting reply like this then your internet explorer is corruptInternet Connection - 3c1a5ad.jpg
Your internet explorer is corrupted. then change with firebox for testing. Afterwards you may reinstall internet explorer for normal use
C:\Progra~1|Mywebs~1\bar\2.bin\MP3PLUGIN.dll
you can do the following,
open the run from start menu..
type "msconfig" and press OK...
goto the startup tab...
there uncheck entry having the same stuff as you have given in the question....(what is on the error)
click OK ..
restart the system it should work fine...
If this works please give a vote........
2answers
C:\PROGRA~1\MYWEBS~1\bar\1.bin\M3PLUGIN.DLL
go to run, type in MSCONFIG and go to startup and uncheck the link that says c:\progra~1\mywebs~1\bar\1.bin\m3plugin.dll and the problem will go away.
Need download of m3plugin.dll
Un-install the program through windows Add/remove programs.
See the link provided below;
progra-1-mywebs-1-bar-1-bin-mp3plugin-dll">http://en.kioskea.net/forum/affich-167900-c-progra-1-mywebs-1-bar-1-bin-mp3plugin-dll
Tip. This program allows adware and spy-ware into your system without you're knowledge. However if you still want it try a re-install after removing it at; http://download.mywebsearch.com/
Good luck.
Mike
1helpful
C:\Progra~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
Not sure what your asking for, Please be more specific.
Thanks
3answers
C:\progra~\mywebs~1\bar\1.bin\m3plugin.dll
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Select "My Web Search"
Click Remove
Restart your computer.
1helpful
C:\PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL -- PLS HELP!! :(
Start
Control Panel
Add/Remove Programs
Select and remove the "My Web" application.
After windows xp loads on startup I get an error message it says: C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL I cannot find the file that might be corropted
Try this:
Click Start>Run>type "msconfig", then click the tab start-up and boot.ini, and see if you can find the C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL being loaded on start up, uncheck it then click okay and then restart the computer
32helpful
6answers
C:PROGA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
I am running XP. I went to RUN - MSCONFIG, then go to START tab. You will find an entry for this DLL. Uncheck to box, choose APPLY, and restart your PC, the nagging pop up on restart should be gone.
3helpful
3answers
M3PLUGIN.DLL
Error loading
C:\PROGRA~1\MYWEBS~1\BAR\1.bin\M3PLUGIN.DLL
The specific module could not be found.
please solf this problem
63helpful
26answers
M3plugin.dll
progra-1maywebs/bar/8.bin/mwbar and 8.bin/m3plugin.dll .may problem with computer
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
