Question about Vacuums
VACUUM - 1. How to open up a Wertheim 5030 to get to the cord retractor 2. How to fix the retractor so that it retracts the cord.
  • cliffordgord Mar 26, 2011
    Thanks for your reply. However, I am a fairly competent diyer and was looking for a non-generic solution from someone who regularly works on my model of vacuum and can tell me exactly the answer. In the interim, I have managed to almost get to the cord reel.
  • Vacuums Master
  • 12,061 Answers
Hi to do this you will have to somehow find a service manual, this will give detailed instructions on why and how. I have searched for one however i was unable to find any. Perhaps a direct plea to the manufacturer may help?
In any event, usually the is NO "Fixing" of the retractor, most often, the mount at the rear attachment of the coiled spring, brakes and this stops it retracting.
The fix is to replace the entire recoiler assembly. This is pretty simple job, if one can obtain the parts.
However my professional advise is to take it to a vacuum repair shop, (NB: Only take it to a repair shop that deals in YOUR brand) and ask for a "Quote" for the repair, I am sure it will be modest indeed. You see this is just such a common thing that they fix all the time.
Posted on Mar 26, 2011
    Genius:
  • 1,622 Answers
Hi,most cord reels have a metal flat spring, wound very tight, like in an old clock (if you remember cartoons very well, you can imagine the spring). It's this coil that retracts the cord. The locking in/out mechanism is similar to a venetian-type blind pull; you can release the blinds, and lock them in any position you choose by pulling slightly at an angle.
The cord reel itself is mechanical; however the cord usually is soldered or otherwise wire-connected to a metallic contact, which in turn is connected to the motor. So if a cord is yanked hard enough to dislodge the connected contact, the vacuum will not run. But, it does take a big yank!
Cord reels, as a rule, are only good for so many ins-and-outs. Eventually they all fail. But, how convenient they are!
Hope this helps.
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
How to disassemble to repair cord retractor?
If you have a BISSELL rewind vacuum you can take a look at these simple tips or take it to one of our Authorized Service Centers: http://www.bissell.com/FAQDetail.aspx?id=8991&cid=ccsocial
Apr 24, 2012 | Vacuums
Cord retractor doesn't work
does it retract at all or not at all? or does it not stop when the cord is pulled out any amount?
Oct 20, 2011 | Electrolux Guardian Bagged Canister Vacuum
Cord will not retract?
This is caused by a broken retractor reel spring, you will need to replace the retractor.
Jan 28, 2011 | Electrolux Epic 6500 Vacuum
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
Sep 14, 2009 | Miele Vacuums
The automatic cable rewind on my Morphy Richards pod vacuum cleaner keeps retracting. I'd rather it didn't work at all than be constantly pulling out the cord. Is there any way in to fix it or disable it?
Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
Jun 19, 2009 | Miele S251i Plus Bagged Canister Vacuum
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Hoover Model S3281, disassembly instructions
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Jan 01, 2008 | Vacuums
Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
559 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
