Question about Sansui Audio Players & Recorders
Sansui intergrated amplifier AU-X410R.... the problem is i linked it up to my cd deck player and it was working fine for ages... and thren one day i turned it on and now sound comes from the speakers!!.. all lights work on the amp and the cd player works fine tried it on diffrent things.. ive tried to search for a solution for the problem with no sound form speakers and cant find anything.. tried diffrent inputs but still no sound and fuses are fine.. what could be the problem??..
  • David Dunn
    David Dunn Mar 26, 2011
    I don't see anything here that says you've tried any other source or input, so we don't know if it's a CD issue or an amp issue. Or how the CD is 'linked up'. Or its model.
jerryg50
  • 1689 Answers
SOURCE: I have a Sansui AU-717
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Posted on Apr 13, 2008
robotek
  • 1512 Answers
SOURCE: I own a classic Sansui
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Posted on Apr 18, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Posted on Jun 26, 2008
welcomejee
  • 10594 Answers
SOURCE: number of inputs
Each CD Player has audio out put amplifier circuit and this output amp remains Mute until it receive signal to out it. While using Y-Connector, when you try to listen one player sound, other goes to Mute as its in Stop position and caused to minimize the out put of other player which is being played. That's why you listen good sound if just one is connected. If you want to connect both players at one amplifier, you need at-least 2 inputs in amplifier and since your Fisher amp has not 2 inputs, so I suggest to buy another amp equipped with 2 or more inputs. Hope this info will help you.
Posted on Aug 17, 2008
What type of connection wires do I need to connect a sansui au 9900a intergrated amplifier,and the tu9900 stereo turner to a kenwood multi cd player and a JVC td- w 5th double cassette.
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
Try this:
http://stereobarn.com/how-to-connect-a-stereo-system1/
Sep 29, 2014 | Sansui Vintage Tu-9900 Legendary Amazing...
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Circuit diagram board for sansui integrated amplifier Au-x410R
Circuit diagrams are in PDF, so cannot uploaded by this window.If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | Prima Televison & Video
Looking for an owner's manual for the Sansui Integrated Amplipier AU-D9.
Hi info851163...
Go to the following website and register to download your Owners/User Manual for your Sansui Intergrated Amplipier AU-D9.
Please take time to rate me thumbs up
http://www.hifiengine.com/manuals/sansui/au-d9.shtml
Also at this website...for $6.92 Canadian Dollar:
http://www.ioffer.com/i/Sansui-AU-D9-amplifier-Service-manual-79410631
Sep 15, 2011 | Audio Players & Recorders
My tascam cd-1500 dj left side only display good day while the right side is fine
how can i b deck going on my tascam x1700 from gd day when i got deck a working i cant remmber what i pressed can any one help
Aug 25, 2011 | Tascam Cdx1500 Dual CD Player CD Player
Sansui AU-X410R Amp, at power on, lights on but no sound (surge protection click doesn't occur). Sometimes powers off for no apparent reason.
One thing you could look at is that thing that makes the click, it could be a relay and they do go wacky sometimes (hence why it shuts down). If you are lucky it will tell you (on the relay) everything you need to replace it.
Jun 11, 2010 | Audio Players & Recorders
Kenwood Components
MAKE SURE U HAVE ALL OF THE COLORS MATCHED UP ON THE WIRES
Sep 09, 2008 | Kenwood KDC-MP4028 CD Player
I have a Sansui AU-717 Integrated Amplifier that needs some work done on it. Is there a Sansui service center in Washington State that can work on this?
Sansui:
Jerry G.
Apr 13, 2008 | Audio Players & Recorders
Spares
Bass Treble,bal controls can be clened with contact cleaner.
Drive belts audio heads may be available at the sansui web site or mcm electronics.com.
GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
322 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
