Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Sprayer handle finish is bad, is it a warranty item? paul
    Master:
    Sergeant:
  • 500 Answers
Cosmetic is iffy id think so, but manufacture may not ,, be persistent ..
Posted on Mar 26, 2011
SPRAYER HEAD A11218 1M 2.2 GPM NEED TO FIND REPLACEMENT FOR THIS ITEM.
The A11218-1 is merely a plumbing standards number. Look further to try and find a manufacturer name or model. Or take it into a local professional plumbing supply store.
Nov 25, 2014 | Plumbing
Front Driver side door on2004 Santa fe will not open from inside
Hi Paul, Im glad to help!
Paul, when you can't open a vehicle door from inside the car, it is because either the latch is bad OR the handle is broken OR the rod /cable that goes from the handle to the latch is either off OR broken. Call me Al 314-374-5218 hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2003 Hyundai Tiburon
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
I have a ca87629csl two handle kitchen faucet with a side spray and I have extremely low water pressure coming out the faucet even with the screen taken out. I think or know that debris in the line has...
If the faucet is plugged AND the sprayer also seems to be plugged, the problem is probably in the diverter valve that controls the water going to the faucet and sprayer, see URL link below. Need to find a way to clear the valve, most likely by removing the faucet neck and cleaning and the reassembling. Prior to doing that I would remove the hose connection and try blowing back through the faucet to see if you can get something out of it.
http://www.moen.com/shared/pdf/ca87621pt.pdf
Please contact me if this does not work. More things you can do, but they are pretty drastic.
Paul
Sep 18, 2010 | Moen 7905 Castleby Two-Handle Kitchen...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
Jan 10, 2010 | Delta Faucet #RP320 Divert Assembly
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
Top Blanco Plumbing Experts
Marvin
Marvin
Andrew Bugbee
Joseph Hoffmann
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
