Question about Vacuums
VACUUM - How to open up a Wertheim 5030 to get to the cord retractor
3 Suggested Answers
SOURCE: VACUUM - 1. How to open
Hi to do this you will have to somehow find a service manual, this will give detailed instructions on why and how. I have searched for one however i was unable to find any. Perhaps a direct plea to the manufacturer may help?
In any event, usually the is NO "Fixing" of the retractor, most often, the mount at the rear attachment of the coiled spring, brakes and this stops it retracting.
The fix is to replace the entire recoiler assembly. This is pretty simple job, if one can obtain the parts.
However my professional advise is to take it to a vacuum repair shop, (NB: Only take it to a repair shop that deals in YOUR brand) and ask for a "Quote" for the repair, I am sure it will be modest indeed. You see this is just such a common thing that they fix all the time.
Posted on Mar 26, 2011
diodeic
  • 1622 Answers
Hi,most cord reels have a metal flat spring, wound very tight, like in an old clock (if you remember cartoons very well, you can imagine the spring). It's this coil that retracts the cord. The locking in/out mechanism is similar to a venetian-type blind pull; you can release the blinds, and lock them in any position you choose by pulling slightly at an angle.
The cord reel itself is mechanical; however the cord usually is soldered or otherwise wire-connected to a metallic contact, which in turn is connected to the motor. So if a cord is yanked hard enough to dislodge the connected contact, the vacuum will not run. But, it does take a big yank!
Cord reels, as a rule, are only good for so many ins-and-outs. Eventually they all fail. But, how convenient they are!
Hope this helps.
Repair wertheim 3180
The hose probably is old enough that it will split repeatedly until you give up and replace it.
Jan 10, 2018 | Vacuums
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
VACUUM - 1. How to open up a Wertheim 5030 to get to the cord retractor 2. How to fix the retractor so that it retracts the cord.
Mar 26, 2011 | Vacuums
Cord will not retract?
This is caused by a broken retractor reel spring, you will need to replace the retractor.
Jan 28, 2011 | Electrolux Epic 6500 Vacuum
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
Sep 14, 2009 | Miele Vacuums
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Sep 28, 2007 | Vacuums
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
