Question about Karcher Garden
I borrowed my neighbor's Karcher Model G 2650 OH (it's several years old). It had the yellow tip already on, but after awhile, I took the tip off to use a different tip,and pulled down the brass coupling at the end of the wand to insert the new tip. The problem is that the brass coupling at the end of the wand won't snap into place around the tip -- so I tried another, and another. No luck. And now the original tip that was on the wand won't snap back into place. HELP! I need to get my neighbor's pressure washer back to him in good shape or better than what I found it. Can this be repaired, and if so, what is causing this? If not, can I get a model number for the wand and the five color coded tips so I can purchase a new wand and stips? And what is the price for both? Many thanks for your help!
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
  • 174 Answers
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
  • 5603 Answers
SOURCE: lose of pressure on Campbell washer
Usual cause is the pressure valve sticks closed and doesn't admit more water to be pumped. Usually needs new O RIngs and cleaning the bore... ABout a 15 minute job at most. Get an O Ring kit for it.
The valve is held shut when pressure on the output is high. When you open the trigger, the pressure drops and the valve opens letting more water come in from your garden hose.
The O RIngs dry out and bore gets dirty. Polish it with crocus cloth on a dowel rod. Lube the O Rings with lube intended for O RIngs.
Posted on May 08, 2010
Testimonial: "You hit the exact problem. After many discouraging information from repair people I got pump to repair in Springfield TN. He took back to shop - 10 minutes back with repair. Man what a releaf .. in a throw away, buy a new world. Thank you... you are great!"
Why does my Karcher pressure washer Pulsates when switched on also leakes water.
Shame you did not leave the model type of "Karcher" pressure washer as there are several models.
There is normally a special oil which should be changed, expect this to be done at least every three years or less.
1/. These pressure washers should only be serviced or taken apart at one of their registered dealers, as far as pulsating if you have the cheaper models then they do not last very long.
2/. Their better more power washers pulsate all the time & that is why they are sold new with a special fitted container, this allows all the pipes & water connections to fit & hold in supplied container, which allows you to give a higher or lower power controller where their yellow pipe that attaches to the gun fits on the machine.
3/. Where the pressure pipe goes into the power washer it has a black knurled fitting to adjust the pressure higher or lower out put, this is the only adjustment you can make on these power washers, everything else needs to be done by their approved dealers, situated all around the world, try finding your nearest dealer through the Internet. Hope this helps. Malcolm.
Feb 07, 2015 | Karcher Garden
Have not used K3.97 for awhile. took out of box and there is quite a bit of oil. Solution?
the pump has a vent and if turned over it could drain out of the pump check the fluid level before using it
Sep 02, 2012 | Karcher K2.26 Electric Power Washer
Leaking water around pump area
Sounds like the water seals are bad in the pump, do you have a model number?
Oct 19, 2010 | Karcher G 2650 Gas Pressure Washer
My karcher pressure washer g 2650 oh wont start
Will it start if you pour a small amount of gas in the carb? If so your carb needs to be removed and cleaned.
Jun 30, 2010 | Karcher G 2650 Gas Pressure Washer
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
There is no pressure
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Sep 11, 2008 | Karcher 2500 PSI Pressure Washer
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Garden Logo
52 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
