Gemini 2 vep-90m heater won't ignite. I'm looking for soution, or owners manual so I can locate igniter. You can smell gas so I'm thinking that's what it might be. Any help would be great thanks.
SOURCE: Heater will not ignite
The igniter should have 120v if it is Hot Surface Igniter (HSI). You may be having a problem with gas pressures. Possible transformer problem also if you changed that with other parts.
Posted on Mar 04, 2008
SOURCE: Pool Heater
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
Posted on May 26, 2008
SOURCE: Lars Lite 2 pool heater will not ignite
The easiest way to troubleshoot any heater, is to call the manufacturer. Their techs will walk you through each possible problem and solution until you find the answer.
Posted on Oct 03, 2008
  • 7 Answers
SOURCE: gas will not stay ignited
could be dirty heater you have to clean the runners and the smole nozzles that are in the manifold below the gas valve it's like a 9/16 size you pull them off and check make sure they are clear through, sometimes little spiderwebs build up inside them. if it's all clean, then it could be you flame rectifier/ aka: flame sensing rod, that tells the htr that there is fire so it keeps running. Let me know what happened.
John
Posted on Jan 06, 2009
steve_lima
  • 181 Answers
SOURCE: heater will not ignite checked lines but heater
what is yor air pressure?have you checked you rotor to see if it is broken.all pro's are note for that.
Posted on Feb 24, 2009
Black oil smelling soot coming out of heater. It also makes a squealing type of noise. It is natural gas. Pressure by utility company already checked. It fires up fine and remains on, but doesn't look...
i think you are on the right track. the gas company will verify the pressure going to unit but it sounds like the gas control valve on your heater may need to be adjusted. for that you will need a licensed gas fitter. call your local pool company or the company who installed the heater. directions on how to adjust the valve will be found in your owners manual
May 30, 2014 | Hayward H Series Pool & Spa Heater...
Laars Lite 2
If the heater is "acting normal" with no failure codes and you smell gas, then I would bet it's the igniter. The fact that you smell gas indicates the heater does not have a failure in any of the safety circuits and wants to fire. It is just missing an ignition source or the gas you smell is not making it to the proper place to be ignited. Given these two options it is most often the igniter. Replacing the igniter is not difficult but it is a VERY delicate part and experience in handling it is benificial.
Apr 14, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Pilot light wont ignite on patio heater
It may be that your cylinder is malfunctioning, cylinder has a leak, or the pilot is clogged. Please see steps below to troubleshoot. Note:Regular maintenance is critical to the successful operation of your patio heater.
  1. Is the cylinder valve closed? If so, open the cylinder valve but not fully.
  2. Check to see if you can light it manually. If the unit lights manually but not with igniter, service or replace igniter switch.
  3. Ensure that there is no air in the gas line. Open the gas line and bleed it (pressing control knob in) for not more than 1 - 2 minutes or until you smell gas.
  4. There may be a blockage in the orifice or pilot tube? Bugs and spiders get into the pilot assembly, venturi tube and burner ports causing the unit to either not light or poor performance.
  5. Is the regulator hose pinched or kinked?
  6. Cleaning the pilot assembly.
  7. If the piezo igniter won't spark to light the pilot, check the wiring to the igniter, It may simply have lost it's ground. Slide the wire off the igniter prong (looks like a thick needle) on the pilot assembly and then push it back on. That usually will reestablish the ground.
If you continue to have problems with the heater, contact Blue Rhino (the manufacturer) Customer Care 800-762-1142.
Hope this helps you to troubleshoot and solve the problem. Please let me know.
Apr 21, 2011 | Uniflame 200209 Open Flame Patio Heater
When I turn on the heater the service heater light turns on after about a minute, it's like the gas never ignites, I think the error code is n 5? Any suggestions
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. There is further diagnostic goes further but that is usually the fix.
Sometimes, when a heater has not been used in awhile, the igniter is always to blame. You really need to fire it off weekly to make it reliable.
But, lets say that the igniter has failed completely, then you would need to replace the igniter.
For a better diagnosis, we would need to know some additional information:
1) Is the heater natural gas or propane? 2) Do you smell gas at any time in the 5 minutes the heater is trying to fire? 3) If you listen closely, can you hear the "tick, tick, tick" of the igniter?
If you are able to provide us this additional information, we will be able to provide you with some more detailed ideas on what is going on!
Thank you for allowing us the opportunity to help and we really look forward to your feedback!
-The Ugly Pool Giy, www.WeFixUglyPools.com
Dec 09, 2010 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Smell of gas. no leaks. no smell when just the pilot on. no smell when bricks are lit. just smells between thermastat going on & the ignition of bricks
If possible, ignite on a lower setting then increase rather than igniting on the high setting.
If there is no manual adjustment, I would call a gas engineer to sort out the problem, as you do not want a malfunctioning gas appliance in your home.
Feb 10, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater problem
i concur, when flame is not sensed gas valve closes
Jun 13, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
