Question about Husqvarna Garden
I need to know how to bypass the safety features on Rz3016 riding mower with a 16.5 hp Briggs and Stratton engine. A wiring diagram or schematic would be nice. I have already removed all the wiring to the safety features and want to hook the engine up with a toggle switch or something bypassing the factory ignition switch also.????
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
SOURCE: lawn mower / could not find a product on lawn mower, but a car mechanic can tell me.
http://www.google.com/search?q=18+HP+briggs+and+stratton+SERIAL+NUMBER+LOCATION&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a TRY THIS.RICHARDM69
Posted on Jan 08, 2009
  • 11 Answers
SOURCE: need a wiring diagram for a model # 2680
hello
tobypass the switch simply remove the wires usually 2 and just connct together this should do it
hope this helps
Posted on Mar 15, 2009
  • 246 Answers
SOURCE: 1998 craftsman mower w/19.5 hp Briggs and Stratton will not fire.
Hello B-N-L:
>>I Suggest you Check the Ign Module First and then the Safety Switches if the Ign Module (Coil) is Good. Remember that the Ign Module May Check Good, but if the Safety Switches Check Good, then Most likely the Coil is in the Early Stages of Breaking Down and will Cause this Problem.
>>You can Check the Ign Module (Coil) by Using the Following Instruction File.
The Following is an Instruction File I Made for Checking and Repairing this Problem.
>>Run the Engine Until it Quits, then Remove the Spark Plug. Wrap a Wire Around the Threads and Attach the Other End of the Wire to the Engine Block Turn the Engine and See if the Plug Fires.
>>If No, then Disconnect the Shut Off Wire at the Control Bracket First, Check for Fire at the Plug. If Still No Fire at the Plug; Then Disconnect the Shut Off Wire at the Coil (usually requires removal of the blower housing) and Check for Fire at the Plug.
>>If No Fire at the Plug , then the Coil/Ign Module is Bad. The Coil/Ign Module to Flywheel Gap is .020in.
>>On Some Model JD Engines, there is a Igniter that Goes Bad and Not the Coil. The Igniter is the Same as an Ignition Module. If the Plug Fires at Anytime During these 2 Checks, then a Safety Switch or Wire May be the Problem. Yes the Engine will Turn Even with a Bad Seat Safety Safety Switch. Usually if the Engine will Not Turn with the Ign Switch; the Blade Safety or Neutral/Clutch Safety Switch is Usually the Cause of this.
>>The Starter Turns and the Engine Doesn't Fire is an Indication of a Bad Coil/Ign Module or a Faulty Blade Safety Switch.
>>The Blade and Clutch Safety Switches Prevent the Starter from Engaging so the Blades or the Mower Does Not Move when the Starter Turns the Engine.
>>The Seat Safety is Designed to Stop the Engine if the Blades are Engaged or the Clutch Safety is Not Engaged when you Leave the Seat.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire.
>>Check the Clutch/Brake and the Blade/PTO Safety Switches First.
>>Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Volt/OHM/Continuity Meter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>If the Safety Switches Check Good, then Check the Ign Module (Coil).
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: need to know if the
Hello:
>>You can View a Breakdown/IPL of this Engine at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM and Enter the Model (5 or 6 Digits) and Type Numbers (first 4 digits Only). Example: XXXXXX-XXXX. Then Double Click on the Model in the Results Area. Select Sectional Index. Now you can Select the Section of the Engine you Wish to View. Select the Carburetor File. This will Show a Breakdown of the Carburetor for you to Check and See if you Assembled the Carburetor Correctly.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
My belt keeps falling off and I don't know how to make it stay on.
I have the same mower. Check the idler pulley that tension the belt when you pull up on the handle. Make sure it turns freely.when there is no tension on the belt. Depending on how long you've had this mower, your belt could have stretched and needs to be replaced. I hope this helps.
Apr 26, 2015 | Husqvarna Rz3016 Zero Turn Lawn Mower...
My' MTD riding mower will not start? the battery is fully change? but just will not started. when I check the oil? it was not good; it was very black, and the oil lever was very high above normal
can you rotate the engine by hand?try and bypass wiring and jump at the starter if ok they bypassing the safety switches and bypassing each battery cable
Apr 21, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
I just need to know where to find a wiring diagram for a briggs and stratton 9 hp engine, model 28a707 type 0122-02
There realy isn't a 'wiring diagram' for this engine. Are you looking for an 'illustrated parts list' perhaps? If so, go to ... http://www.partstree.com/parts/.... scroll down to Engines, click on Briggs and Stratton, then enter the model # and type # on the left. Leave out the word 'TYPE'... just put a - between the model, type and trim numbers. The parts are available anywhere. This site is just a good reference for mowers and engines diagrams..Hope that helps.........
Aug 14, 2011 | Garden
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
How do i change out the Crank Shaft in my Briggs and Stratton 16 HP Horizontal shaft L-head model number 326431? I have the engine torn down and am having a problem getting the crank shaft and cam shaft...
if you look on you tube there are loads of good vids about briggs and stratton engines. also the briggs and stratton web site has exploded diagrams for all engines, they also sell manuals, ebay also sell the cheaper.
steve
Aug 27, 2009 | Garden
Murray riding mower Mod. #30575x8a will not start.
Hello:
You can View a Schematic at the Following Site Addy. Select the OEM Briggs and Stratton (Murray Power).
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Garden
Garden Logo
61 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
