Question about Metz 58 AF-1 FLASH f/NIKON TTL Flash
Using Sunpak TR-PAK II with Metz 58 AF-1
I would like to adapt my Sunak TR-PAK II high voltage battery pack for use on my new Metz 58 AF-1, using the Metz V58 power cord, which normally connects to the Metz P76 battery pack, which sells for around $500..ouch!
My question is, why are there 4 pins on the V58 power cord, what is the little "box" on the cord, and is it possible to adapt a two pin 330 volt cord to the Metz 58 AF-1 flash. I understand that the automatic functions on the Metz 58 AF-1 will work without internal batteries when using the high voltage P76 Power Pak. Is one of the additional connections for a low voltage to run the control circuitry in the flash? Any help would be appreciated.
Art Trevallee
4 Suggested Answers
  • 7 Answers
SOURCE: Metz 58 AF with Nikon d90 wont flash
If you hear rattling or a grinding sound/feel .. can be flash tubes broken.
Posted on Jul 21, 2009
  • 22 Answers
SOURCE: AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Posted on Feb 28, 2009
Obertelli
  • 3006 Answers
SOURCE: my metz af-2 flashes "power
Which EXACT batteries are you using?
Posted on Jun 23, 2011
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
I had metz 58 af for nikon mount can i convert it to canon mount
No. The Metz 58 is not designed as a part of a modular system.
Aug 10, 2011 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I'm new to photography and have a Nikon D-50 with a Metz 58 AF-1 digital flash. Where can I find a users manual?
Metz 58 AF-1:
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_58_AF_1_digital_Nikon_D_F_NL_GB_I_E.pdf
Nikon D50:
http://support.nikontech.com/app/answers/detail/a_id/13644
Sep 04, 2010 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
On the 622 pro Sunpak
Sunpak TR-Pak II a NiCad flash battery pack with charger and Quantam battery both has cords for 622.
Personally I have taken out wire pair from removable battery pack of 622 and connected to 4 cells of Nicd type D battery pack made at home.(I placed that in my belt bag).
want more details ,feel free to email at bforbay@gmail.com
Mar 29, 2010 | Sunpak 622 Super Pro TTL Flash
Metz flash 58 AF exploded
If you are interested to buy new
Metz 58 AF-1 FLASH f / NIKON TTL Flash
click the link below
http://www.amazon.com/Metz-MZ-58314N-Flash-Cameras/dp/B000M21J56
The replacement of bulb is simple, just push front cover upward and pull it outward the cover will be opend. Now pull out bulb and place a new one and shut the front cover gently.
Thanks eo share your problem with FIX YA.
Aug 16, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Open Questions:
Metz 58 AF-1 FLASH f/NIKON TTL Flash Logo
96 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
