Question about General Electric 28106FE1 1-Line Cordless Expansion Handset
No se como registrar el auricular del GE MODELO 28106FE1-A
  • 10 Answers
SOURCE: pedro
http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip
Posted on Jul 31, 2008
SOURCE: Tengo telefono GE modelo 27831 x 2 y uno de ellos no funciona
La solucion es super sencilla, simplemente debe poner el auricular auxiliar en la base principal durante 10 segundos y luego ya va a funncionar, por que es la base la que que debe identificar el teléfono, ya que la base auxiliar solo es un cargador.
Saludos...
Posted on May 06, 2009
  • 454 Answers
SOURCE: necesito el manual de usuario de la heladera
You can download the user's manual in Spanish at http://espanol.geappliances.com/enes/service_and_support/literature/
Posted on Feb 06, 2010
gopakumarg43
  • 75581 Answers
SOURCE: Cual es el codigo para programar lcd samsung con control remoto universal marca GE modelo 24993-3?
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Jul 30, 2012
SupportByK
  • 10322 Answers
SOURCE: compre una mini cam pro
1st You download Webcam Driver.
Compre una mini cam pro
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Nov 26, 2012
Zte n9511 la pantaya esta negray no se puede ber nada
Lo primero seria buscar en Google "Como hacer ZTE N9511 nuevo de f?brica". Si puedes ver videos mucho mejor. Esto lo que hace es entrar en una secci?n del celular conocida como recobrar, o recovery en Ingl?s. Si el celular prende, y logras acceder al recovery, que se pueda ver la pantalla, entonces puede ser una falla del SO (Sistema Operativo). Mediante el recovery puedes hacer nuevo el celular como si fuera de f?brica, o sea, como cuando se compra nuevo de la tienda. Esto repara el SO, haciendo que el celular vuelva a trabajar.
Este video es el que mas se asemeja a tu modelo.
Apr 02, 2015 | ZTE Cell Phones
Tengo un suzuki aerio del 2003 y se salio de tiempo.... Como pongo los palos para que este en tiempo de nuevo y encianda el carro?
oye anda para un autozone or pepboys y compra el manual pa tu carro. en ese libro te dice como setiar el motor en tiempo para que sirva e prender el motor. puede costar como 15 a 25 dollares... suerte joan9011.... se llama haynes repair manual pa tu modelo o chiltons repair manual
May 10, 2011 | 2003 Suzuki Aerio
PERDI MI MANUAL DEL TELEFONO INALAMBRICO BEETEL 2.4 GHZ DIGITAL, NECESITO REGISTRAR EL AURICULAR EN LA UNIDAD BASE.
POR ERROR BORRE REGISTRO, COMO LO REGISTRO NUEVAMENTE? EN LA PANTALLA SALE REGISTRAR! MI CORREO ES : lcasinos@hotmail.com GRACIAS!
Mar 26, 2011 | Cell Phones
Se me rompio la pamtalla de un lcd 32" LG COMO HAO CUANTO ME CUSTA S PUEDE O NOOOOOOOOO GRACIAS
Disculpa mi pantaya sanyo modelo dp32649 se estreyo la pantaya del lado derecho si se ve el izquierdo y el audio tamb funciona tiene reparacion o como le pdo aser grax
Jan 22, 2011 | Televison & Video
Como puedo volver a registrar el tel si ya estaba en uso pero se borro el nip que ya tenia
primero tienes que presionar la tecla de registro/localizacion que se encuentra en la base por aproximadamente 3 segundos como minimo, luego la sueltas y le das en menu OK, luego configuracion OK, auriculas OK, Reg, auricular OK, y ahi te pide el PIN, son 0000 (cuatro ceros) OK, y eso es todo, tarda un minito o menos en registrarse, si tienes mas de un telefono, con cada uno de ellos tienes que hacer el mismo procedimiento y eso es todo, espero aun te sirva :)
Jan 02, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Como conectar bluetooth madcatz playstion 3
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
Dec 28, 2010 | Mad Catz Bluetooth Headset for PS3
No se como activar el bluetooth
pon el modelo del radio para poder ayudarte!!!
Jun 02, 2010 | JVC KD-G230 CD Player
General Electric 28106FE1 1-Line Cordless Expansion Handset Logo
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
