Question about GE SDVR-16PII-160 StoreSafe 16-Channel StoreSafe Pro II, 160GB
I have 2 units StoreSafe SDVR-16-160, 1 is connected with 9 cameras and the other is connected with 8 cameras, for the last 3 years this equipment works well. However the energy supply was lost for a week and when we have power again only 2 cameras are available in each one of the SDVR's I try resetting the units, and even setting the factory defaults, but still the same only 2 cameras in each monitor Can you give a tip, how to recover my other cameras??? Thanks Antonio Garcia, Xalapa, Mexico.
    Top Expert:
  • GE Master
  • 24,773 Answers
The capacitors will be dried out. Replace the cameras or get an electronics engineer to replace the capacitors in all of them.
Posted on May 24, 2017
3 Suggested Answers
SOURCE: I need a manual for GE Security Storesafe SDVR-10PII-80
I have one for you. contact me
Posted on Mar 13, 2009
  • 2777 Answers
SOURCE: I have a ge dvr
You are going to need to contact the manufacturer to have them assist you in bypassing and then resetting that second security code. There is no simple way to just get around it... it is hard coded now to memory inside the unit. You would need to take apart the whole system and take out all the internal batteries, but it is very difficult and delicate work. Then leave them out and leave it unplugged for at least an hour, that should erase the memory and all stored passcodes, but it is not easy at all.
Give GE Security a call to get assistance with this from a live person. Their number is 1-888-437-3287
Posted on Oct 10, 2010
Sdvr cctv won't stop beeping beeps about 3 times every 10 min and evetually lose everything on monitor motion is off overwrite is on. seems to be recording though
Sounds like a trouble signal. Possibly a problem or difficulty with your security system, such as a loose wire, a poorly aligned sensor or a low battery status.
Jun 19, 2016 | Home Security
Mack Fault Codes List
1-1 Engine Oil Pressure Sensor
1-2 Barometric Pressure Sensor
1-3 Fuel Temperature Sensor
1-4 Ambient Air Temp Sensor
1-6 Starter Input
1-7 Engine Coolant Level
1-8 (ASET CEGR) Estimated % Fan Speed
1-10 Aux. Cooling Relay Output
2-1 Engine Coolant Temp Sensor
2-2 (ASET IEGR) Boost Air Pressure Sensor
2-2 (ASET CEGR) Boost Air Pressure
2-3 Intake Air Temp Sensor
2-4 Trans Oil Temp Sensor
2-5 Front Drive Axle Oil Temp Sensor
2-6 Rear Drive Axle Oil Temp Sensor
2-7 Engine Oil Temp Sensor
2-8 (ASET CEGR) Combustion Air Temperature
2-9 (ASET CEGR) Combustion Air Temp Sensor
3-1 Exhaust Temperature Sensor
3-2 Engine Speed Sensor
3-3 Redundant Engine Speed
3-4 Engine Position Sensor
3-5 Engine Brake Output #1
3-6 Engine Brake Output #2
3-8 Trans Splitter Position
3-10 (ASET CEGR) Engine Brake Output #3
4-1 Vehicle Speed Sensor (VSS)
4-2 Fan Clutch Output
4-3 Auxiliary Output #1
4-4 Auxiliary Output #2
4-5 (ASET IEGR) Wastegate Output
4-5 (ASET CEGR) VTG Position Sensor
4-6 Tachometer Output
4-7 Speedometer Output
4-8 Customer Defined Statement
4-9 (ASET CEGR) EGR Valve Mechanism
5-1 Throttle Position Sensor
5-2 Throttle Position Sensor Reference Voltage
5-3 Engine Shutdown Lamp/Alarm
5-5 Electronic Malfunction Lamp
5-6 Spare Relay #3
5-7 Engine Oil Level
5-8 (ASET CEGR) EGR Temperature
5-9 (ASET CEGR) EGR Mass Flow
6-1 Fuel Level
6-2 (ASET CEGR) Turbocharger Speed
6-3 J1708/J1587 Link
6-4 J1939 Link
6-5 All Communication Lost - Engine Shutdown
6-6 Fuel Control Module
6-7 Power Relay
6-8 J1939 Link
6-9 Other ECU Affecting Operation
7-1 Service Brake Switch
7-2 Parking Brake Switch
7-3 Speed Control SET Switch
7-4 Speed Control RESUME Switch
7-5 Battery / Alternator Voltage
7-6 Switched Voltage
7-7 Exhaust Temp Reference
7-9 VTG Actuator
8-1 Electronic Unit Pump #1
8-2 Electronic Unit Pump #2
8-3 Electronic Unit Pump #3
8-4 Electronic Unit Pump #4
8-5 Electronic Unit Pump #5
8-6 Electronic Unit Pump #6
8-9 Solenoid Boost Voltage
9-1 Transport Protocol
9-2 Power Reset Without Key Switch
9-3 (ASET CEGR) Aftercooler Outlet Temperature
9-5 (ASET CEGR) Compressor Discharge Temp
9-8 (ASET CEGR) Auxiliary Output Device #1
9-9 (ASET CEGR) Auxiliary Output Device #2
9-10 (ASET CEGR) Auxiliary Output Device #3
10-1 (ASET CEGR) Internal Sensor Voltage
10-2 (ASET CEGR) 5 Bolt Supply
10-3 (ASET CEGR) Sensor Supply Voltage #1
10-4 (ASET CEGR) Sensor Supply Voltage #2
10-5 (ASET CEGR) Fuel Filter Differential Pressure
10-6 (ASET CEGR) Fuel Delivery Pressure
10-7 (ASET CEGR) Odometer Save Area Failure
10-8 (ASET CEGR) GPS Position Data Not Received
10-9 (ASET CEGR) Watchdog Timer Reset
on Dec 20, 2016 | Cars & Trucks
Engine type
There are several engine types
1. 3 cylinder
2. Straight 4 cylinder
3. Horizontally opposed 4 cylinder
4. Straight 5 cylinder
5. Straight 6 cylinder
6. Horizontally opposed 6 cylinder
7. V-6
8. V-8
9. V-10
You can find all these engines in various vehicles produced in the last 20 year whether they be gas, diesel, carburated, fuel injected, super charged, or turbo charged.
Apr 28, 2016 | Cars & Trucks
Anyone having problems with their Keurig coffee maker? I have had two in 9 months. First one lasted less than one month, second one lasted 8 months. Like the coffee but products they are making for
It is cheap machine for the price. The design is inefficient . Consider another brand. But in all fairness, normal maintenance is needed. 90 % of the reason things break down is due to little or no maintaining of the equipment.
Feb 02, 2013 | Keurig Special Edition B60 Coffee Maker
Front right hub and sensor assembly or a diagram
Removal Steps
1. Torsion bar
2. Wheel speed sensor
(if equipped with ABS)
3. Back plate
4. Lower ball joint
5. Upper ball joint
6. Knuckle assembly
7. Oil seal
8. Thrust washer
9. Needle bearing
10. Knuckle
Installation Steps
10. Knuckle
9. Needle bearing
8. Thrust washer
7. Oil seal
6. Knuckle assembly
5. Upper ball joint
4. Lower ball joint
3. Back plate
1. Torsion bar
Mar 01, 2011 | 1999 Isuzu Trooper
Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at (test equipment) section.
Sep 22, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
GE SDVR-16PII-160 StoreSafe 16-Channel StoreSafe Pro II, 160GB Logo
1,063 people viewed this question
Top GE Home Security Experts
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
