Question about Mantis Gas Mini Tillercultivator 2cycle Model 7225
I have a manis tiller that wii not run rigth. i have put i a carber kit
My mantis tiller ran fine,I put it up for the winter and now it won't start,I checked to see if it was getting gas which it was, could it be the coil? I did check and they say its very rare that the coil goes out.I also check for any type of spark and nothing. Please help!!!! thanks ,Clay
Posted on Mar 31, 2011
  • mantispro Apr 22, 2011
    I have your solution guaranteed, I fixed mine yesturday remove H L screw plastic caps and on high 11 threads exposed and on the low side 8 threads exposed. removing the plastic caps allows u further adjusting these wear out or move soo just take them things off and you will be rolling
Mantis tiller
Stan, I would suggest checking the air filter is okay first. It sounds like its struggling for air intake.
Jul 08, 2014 | Mantis Garden
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
I have a older troy don't know model number i need a carb kit
You probley have a briggs & stratton engine. If so, look for the engine model number which will be on the cover. You will need model number and type number. Your carberator will be part of the engine specs. Then you can go online to
mtd/parts
and find the kit you need or take model and type numbers to your local lawn mower dealer and they will either have it in stock or order it for you. Cost is around 15 bucks.
May 28, 2010 | Troy-Bilt Pony Garden Tiller
My Sears rototiller will only start when I put gas directly in the carberator and then stalls out.
Sounds like you need to clean or replace your fuel lines. (Tubing/hoses) that model is pretty cut and dry with how its set up to pull start. Or maybe the gas in the tank is OLD? Try running a tube from a small can of fresh gas, to the carb. If it runs that's your problem!
May 02, 2010 | Craftsman 8.50 Torque Rating Dual...
My tiller only starts when I pore gas into the carberator air inlet. Then it surges for a couple of seconds and cuts off
IF THE TILLER HAS BEEN SITTING A WHILE I WOULD CLEAN THE CARBERATOR SOUNDS LIKE GUM BUILD UP. I HAVE HAD LUCK WITH DRAINING ALL THE OLD GAS AND DUMPING CARB CLEANER IN THE TANK WITH GAS AND KEEP TRYING TO START SOME TIMES THE CLEANER WILL DO ITS NJOB AND CLEAN THE GUM OUT OF THE PORTS IN THE CARB
Oct 12, 2009 | Troy-Bilt Pony Garden Tiller
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
May 20, 2009 | Honda 8 HP Engine
Mantis Gas Mini Tillercultivator 2cycle Model 7225 Logo
241 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
