Stitching coming out is usually an indication that the top or bottom thread is not under tension during seaming.
Check the bobbin thread is under tension (held by a tension spring) and is firm if you pull gently on it.
Ditto for the top tension, dial should be set to a mid number like 5, lower the pressure foot and then pull the thread just before the needle. Does it feel firm?
If you don't have a manual or aren't sure on threading path, its a good idea to track down a manual on-line or a generic threading diagram may suit.
Try www.sewing.about.com, www.sewingpartsonline.com or www.sewingonline.co.uk to try and find the info specific for your machine.
