Question about Power Acoustik CPT12200D Car Amp
I start using it for a couple of months then once start turning on protection ligth and in a couple of second later the protection ligth turned off and the amp never work again
  • 384 Answers
Hi There and Welcome to FixYa,
In many amplifiers, this condition that you have can mean that it has either a power supply failure or a blown fuse. The cause of this can most of the time attributed to sudden drop in voltage.
With this, I am strongly recommending that you have this amp checked by a technician to determine if you have :
  • Melted fuse
  • Or if the fuse holders are still usable
Generally, when the fuse holder melts, the contacts become badly oxidized and the clips lose their tempering - this means that it will continue to overheat and will not function properly, hence, the problem that you're having right now.
I certainly hope this helps,
Thank you for using FixYa.
Posted on Mar 26, 2011
Why would the engine stop after being run an hour a month for a couple of months?
The first thing I would do is drain out the old fuel and put in fresh.
Feb 07, 2016 | Honda Electrical Supplies
Won't turn on, left unplugged for months and then it worked for a couple of months and now won't turn on
Most times caused capacitor problems of well deformed capacitors with to tigh voltage tolerance replace if find bulged or leaking ones with 10 volt higher models the protection mode should after start being activated because of secundairy power supply voltages are no longer smooth flattened and become too high, A heartfelt tip for research , do not use a variac to circumvent the protection power supply voltage without the use of a 200 w lamp in the serial ac line of the primary circuit when troubleshooting , or it will fire -out otherwise undetected a few piece of sometimes hard to get expensive active components.
good luck
Nov 01, 2015 | Philips 52PFL5704D 52 in. HDTV
My TV 52 HDTV start and cople seconds later turns off
That can be caused by either the deflection board or the signal board. If you contact the guys over at www.tvrepairworld.com they can help you properly diagnose the issue and they have replacement parts as well.
Oct 19, 2012 | RCA Televison & Video
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
Mant Req reset ligth
Hello, My name is JShreader. Thank You for choosing fixya.com.
There is 2 ways to do this on this year model...depending on the Month the vehicle was manufactured. 1 is using the Key Slot on the Cluster (on the earlier models). You can do this by inserting the ignition key into the slot located on the front of the instrument cluster lens. When reset, the indicator's colored tab will return to green.
The other way (on the later models) is to use the Reset Button on the Cluster. With the Ignition Switch 'OFF', press and hold the Reset Button. Now turn the Key to the 'ON' position (not starting) while continuing to hold the Reset Button. Hold the Reset Button down for more than 10 seconds. Your Maintenance Required Light should now go out.
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader.
Mar 31, 2009 | 1999 Honda Accord
Ps3 wont start
it only means ur ps3 overheated.. read the instruction manual.. its all there.. when your ps3 starts to blink red it means it overheated.. dont use it for a week or two.. it might work then
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
98 Ford Explorer wont move in reverse or overdrive
Probably low oil pressure in the transmission or worn clutches.
Mar 09, 2017 | 1998 Ford Explorer
Power Acoustik CPT12200D Car Amp Logo
90 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
