Question about Microsoft Windows Vista Ultimate Edition
What is a good process identifier? - Microsoft Windows Vista Ultimate Edition
  • 158 Answers
Autoruns by sysinternals
Posted on Mar 26, 2011
How do I turn off the screen keyboard that comes on whenever I turn on the computer
- First, identify which program is popping up, second prevent it from loading :
1) while soft keyboard is on screen, run the Process Manager (CTRL+SHIFT+ESC), go to the Apps Tab, look for a program with KB in its name, kill it (or, exit the keyboard program, keeping an eye on process manager, in order to identify the prog that terminates) : if it was the right one, then
2) type WINDOWS+R, msconfig, go to the startup tab, and uncheck the line containing the identified program and validate.
Dec 30, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
My acer 4315aspire laptop problem is .1st i on a laptop and my laptop screen is completely white.then i restart my laptop so screen is good during a work screen is again white.so plz help me my problem...
hi.
your problem is there are 4 possibilities.
1 - LCD problem
2 - problem with LCD cable
3 - inverter problems.
4. display card problem
to identify the problem, you have to do troubleshooting.
1 - The first thing you should connect the external display
(monitor) on buieldin display
If display appear in a normal on an external display, this means that there is no problem on display card.
2 - If you have identified the problem not the display card, you have to do further troubleshooting process by opening the cover lcd screen on your laptop, and perform troubleshooting of hardware one by one in the list.
1 - LCD screen
2 - Inverter
3 - LCD Cable
after you do all of these processes will know your results.
Normally the problem is the lcd screen.
Regards
Apr 29, 2011 | Computers & Internet
THE TASKMANAGER'S PERFORMANCE SHOWS 100% USAGE EVEN WHEN THE COMPUTER IS NOT PERFORMING ANY TASK.SPEED OF THE COMPUTER HAS BECOME VERY SLOW.
Start by identifying the processes which are using the cpu and stop them or disable the processes which are causing the usage.
Mar 07, 2011 | Computers & Internet
I closed a file after using it a few days ago. The next day I tried to reopen it and was faced with the message:"File already exists in memory." Since then I have been unable to open the file or...
reboot your computer and try again. This error simply means that that file is associated with a process and is active. identify the file name, and the press ctrl+alt+del. open the task manager and select the processes tab. somewhere in here there is a processes that is attached with that file. find it and 'end process tree' then try again If problem persists, try booting in safe mode by hitting F12 or F8 depending on your system at startup and select 'safe mode' if the file functions correctly then you may want to roll your system back to before you ran that file for the first time or if you are capable, you can track it down by identifying what processes are currently running and which ones appear after windows loads in regular boot mode. Then you can begin to isolate the process and possibly the problem.
(also, make sure that the file isnt in the startup folder)
GOOD LUCK AND PLS RATE THIS POST!!!!!
Nov 12, 2010 | Computers & Internet
Trying to identify the mother board
There are two ways how to identify the brand name and model of your motherboard.
1. Look at it method
* check for labels somewhere in your motherboard
like ASUS P5GCMX .
2. Check your bios by pressing delete during POST boot up process.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
At times my HP 520 laptop battery does not charge...and i fail to understand that what is the problem.... and surprisingly its battery starts to charge.
Try your laptop with a good previously checked AC adapter (check the battery charging process). Than try your laptop with another known good battery (with the same good AC adapter). If problem is not yet identified, you should have your laptop checked by a professional : your mainboard might have a problem.
Oct 04, 2009 | HP Computers & Internet
Dometic model 3663 top freezer works great bottom warm only goes to 50 . have checked flu, flame, gasket seems ok
Here's a good troubleshooting step-by-step process to help identify and resolve the problem you're experiencing.
http://gasrefrigeration.net/does_not_get_cold.htm
Hope you found this helpful and best regards!
Jun 30, 2009 | Dometic NDR 1292 Refrigerator
Phaser 8200DP error 07,002.44:40280 Can you identify this fault for me and tell me how fixable it is?
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic test. Also exercise processes run with the process motor; transfix, drum maintenance and head tilt. This can be caused by the power control board. The process motor may have more than one task initiated. Reset all solenoids and the pressure roller prior to cycling power.
Aug 11, 2008 | Xerox Phaser 8400 Laser Printer
Need down load for ports for pixma ip1600
I am not sure what you are asking for.
Some printers need to be identified somewhere in the Installation process at which time the Ports are Configured for the printer. With Epson, the printer is left switched off until you are asked to switch it on; at which time the Ports are identified and configured.
If you still want the downloads for the Printer, they can be found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11642
Good luck.
Apr 14, 2008 | Office Equipment & Supplies
Microsoft Windows Vista Ultimate Edition Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
