Question about Dell E193FPC 19" TFT LCD Flat Panel Monitor
My dell e139fpc will not turn on and it says its on power save mode and to push any key to turn on but it will not turn on after that. also i heard it might be the battery so i'm trying to find the battery inside but i cant locate it. i dont want to mess up anything else. please help.
5 Suggested Answers
SOURCE: Dell Monitor problem
check the secondary section, something is short. not sure what it is may be 5 volts regulator exceed voltage, EHT transformer drive transistors are short (some used the SMD) or may be the Power supply is not giving proper voltage (not able to take load).
Posted on Feb 08, 2008
SOURCE: Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Posted on Apr 28, 2008
SOURCE: Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Posted on Dec 23, 2008
  • 732 Answers
SOURCE: dell monitor in power save
rtillett, May not be "power save" problem! Possible internal component failure causing "black screen of death" symptom. What is "date of manufacture" from rear of unit? Unit could be 4-5 years old. retrevo .com lists as time to retire and buy new. You should see some video clips at YOUTUBE that show DIY owners/technicians that successfully refurbish these e172, e173 displays to help you decide to spend $20 or trade for new $200 (new unit) wide screen display. Also spand some time reading and following links you find in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" that will help you decide fate of your e173fp unit. Please rate this response AFTER you do your research here and at YOUTUBE. After you discover the common power supply capacitor failure problem that plagues the entire lcd monitor / tv industry you will then be in a much better position to make decision. 12fixlouie
Posted on Aug 17, 2010
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My dell computer says its in power save mode
Press any key or the mouse to take the computer out of power save mode, else push the power button for 5 - 10 seconds until the computer powers off, disconnect the power cable to it for 30 seconds, connect it back and power on, it should show the normal boot up information.
Mar 18, 2009 | Computers & Internet
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
NO VIDEO ON DELL INSPIRON 1501!!! PLS HELP ME!!!
ok
when u power up the paltop press F8 key then go to last known good configuratuion if probelm remains same then chosse safe mode then remove your network driver from it.
also try to rest your defauls sdetting in bios .
when u power yup the laptop press del or F2 or F5 to F12 try this key one by one.
then go to load defauls settitngs then save that settings.
also check in enable vga mode when u press F8 key at power up.go to enable vga mode tthen settings of disaply porperties.800*600 or 1024 *768.
Nov 10, 2008 | Computers & Internet
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Nov 30, 2007 | Dell E173FP 17" LCD Monitor
Dell E193FPC 19" TFT LCD Flat Panel Monitor Logo
51 people viewed this question
Alun Cox
