Question about LG WM2487H Front Load Washer
Cannot remove lint filter located left, front, lower left side
  • 1 more comment
  • finchley856 Mar 26, 2011
    I turned and turned the filter know.... the filter won't pull out. In fact, I tried to force it out and the knob came off the filter. The know is spring loaded when tightened, so I think the filter is sealed tight after I reconnected the knob.
    Can I take just the panel holding the filter out or the entire front of the machine?
    Keith,
    There is a metal panel on the other side of the plastic filter cover. It appears that the filter might be connected to this panel (???). I'm reticent to remove the metal panel, as it seems to be part of something bigger.... What think?
    Ed
    Guru:
  • 262 Answers
All you do is open the small door at the bottom of the front panel it is maybe 6-8 inches long and turn the filter counter clock wise to undo it, then pull it out.
Posted on Mar 26, 2011
  • Keith Drake
    Keith Drake Mar 26, 2011
    You will need to take off the front panel and get to the filter housing and pump.
    Go to this website.
    Click on the link http://136.166.4.200/contents/Laundry/WM...
    Download the service manual located on the far left hand side of the page.
    This manual will show you how to take off the front panel and get to the filter and pump.
    The filter housing is secured by three screws. You will need to do this to replace the filter cap that was broken off.
    If you need further assistance please post.
    Keith
  • Keith Drake
    After unsrewing the one screw (outside of the filter cover) simply take a small flat head screw driver or putty knife to both sides of the filter cover and pull it off.This will expose the filter.
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
How to remove lent filter holder on whirpool affinity dryer
Here is a walk through for accessing the elements, etc, which will get you in the same area your trying to get to.
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design
Jun 03, 2012 | Whirlpool Dryers
Lint filter won't go back in whirpool
something more than likely fell into the lint trap area. Here's a general walk through that should help you get There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.it apart.
Jun 02, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Remove front of dryer
May 31, 2012 | Kenmore Dryers
Need to clean lint from dryer cabinet
Here is a list of possibilties that could be making the noise your hearing:
1) Drum rollers - These are located inside the machine on the rear wall and sometimes on the front panel as well. The rollers should be free spinning when you have gained access to them.
2) Idler pulley - This is what keeps tension on the belt and is located inside the machine in the vacinity of the motor, usually directly in front of it. This should spin freely with the belt removed.
3) Blower wheel - This is located inside of the machine on the lower left side. This is connected to the motor and should be easily turned. You'll want to check that this is free of any obstructions
4) Located on the lower left side of the machine it is very unlikely that this is the culprit, yet if all other parts listed above pass inspection then the this will be the problem.
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
May 25, 2012 | Amana NED7200TW Electric Dryer
Disassemble kenmore 970c8810600 dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else. If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
May 10, 2012 | Kenmore Dryers
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY IT IS WORKING BECAUSE IT HEAT BUT THE CLOTHES ARE WET
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Oct 13, 2011 | General Electric Dryers
I need to clean the lint filter on my whirlpool duet front loading washing mashine. where is it located and how can I get to it?
Its not really a lint filter ,it catches everything that gets down to the drain pump.You need to remove the lower panel on the front of the unit(three small screws one on each side and one in the center down at the floor) pull out bottom of panel to axcess the drain pump. MAKE sure to unplug before working inside.drain pump will have two hoses running to it ,to clean out the filter (trap) turn the cap facing you to the left to remove some water will drain out have a towel to catch reinstall everying in reverse order .sounds like a lot but is actually very easy after the first time
Aug 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you replace a belt on model 11060622990
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
LG WM2487H Front Load Washer Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
